O0 Ia |
Newbie ![]() Group: Members Posts: 4 Joined: 13-July 04 From: unFairfax County - NoVa Member No.: 2,346 ![]() |
I'm looking for a recommended oil weight for winter driving. I currently have Brad Penn 20w50. Is this too heavy for winter driving? Do I risk blowing an oil seal running this oil in 30 degree Fahrenheit weather?
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Yes. Though many of us have done it. I have used the 20w50 down to 33 degrees at times but my case has threaded gallery plugs. At start up it pegged my pressure meter.
Move to thier thinner oil for winter driving. Zach |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
yes its too thick.
When I was driving in the winter...and it get really cold here, I went to 10W30... For your climate, 10W40 should be fine. We get to -20 degrees at night here...and any oil is super thick at that point. Consider putting it inside...an extra 10 degrees makes all the difference from what I have found. Most garages stay above 20 degrees. Rich |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
To elaborate on what (the other) Rich said, and to answer the question you didn't ask - it's not the driving - it's the starting.
If it's garaged and carefully warmed up before hitting the cold, you should be OK. If it's parked in the cold, and you start it there, this is where trouble ensues. When I had to park the 911 outside in single-digit temps I would typically see my 10 Bar pressure gauge peg - even with Mobil-1 15-50, even with keeping the revs down. The upside is you'll probably never see oil temps high enough to cause concern, even with thinner oil. The other unspoken hazard is that many 'high performance summer' tires traction drops off dramatically under about 40ºF. And don't even think about snow... 'All Season' tires are better behaved in the cold - but they're also way less fun in the summer. And in any case, stay off the road as soon as the salt starts... |
potomacmidget |
I gotta have more cowbell.... ![]() ![]() Group: Members Posts: 161 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States ![]() ![]() |
I live in the peoples republic of Maryland - and I put brad penn 20/50 in my car this summer. Should I drain and run brad penn (green colored oil) 10W/30 for the winter? I definitely want to drive the car in the winter.
thanks Reg |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
I recommend changing weights when the time changes to/ from DST. For the majority of the US this is perfectly timed with climate changes.
You will all have another proven oil choice come January... Those on my newsletter list will know details tomorrow. Development work that started in 2005 can finally be taken advantage of by the masses. |
VaccaRabite |
The few times I have had to drive my car when it was freezing I hated seeing the pressure gauge peg on startup. I find it's best to keep dicking with the car so that I just don't get a chance to drive it, rather then Changing oil. (IMG:style_emoticons/default/wink.gif) Zach |
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
(IMG:style_emoticons/default/agree.gif) The few times I have had to drive my car when it was freezing I hated seeing the pressure gauge peg on startup. I find it's best to keep dicking with the car so that I just don't get a chance to drive it, rather then Changing oil. (IMG:style_emoticons/default/wink.gif) Zach (IMG:style_emoticons/default/dry.gif) Dont make me start another poll for 2012 |
AndyB |
The Governor is watching me ![]() ![]() ![]() Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States ![]() |
(IMG:style_emoticons/default/agree.gif) The few times I have had to drive my car when it was freezing I hated seeing the pressure gauge peg on startup. I find it's best to keep dicking with the car so that I just don't get a chance to drive it, rather then Changing oil. (IMG:style_emoticons/default/wink.gif) Zach (IMG:style_emoticons/default/dry.gif) Dont make me start another poll for 2012 No point Joe. You know its gonna be the FIT again (IMG:style_emoticons/default/poke.gif) |
VaccaRabite |
I have a lot to sell at Hershey this year - more then may fit in the 914. If the car is running I may have to tow it.
Joe, get your engine dropped so I can scavenge all the bits I need for mt EFI project! Zach |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
Back in the old school days, the makers put a little booklet in the glove box that has a page in it with the factory recco'd oil weights for temp. ranges & other really good info about your car in it. (IMG:style_emoticons/default/shades.gif)
I always encourage my 2 kids to read theirs, might help to do so for your question. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) and...... (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 25th June 2024 - 09:29 PM |
