Can't turn left... |
WolfR32 |
Oct 31 2011, 09:42 PM
Newbie Group: Members Posts: 47 Joined: 19-September 07 From: Newbury Park, CA Member No.: 8,130 Region Association: Southern California |
So I'm having a short or an open in the ignition wiring or something, when I turn the wheel left slightly the motor dies, if I turn it more its ok, right its fine...
Any ideas? Ignition switch broken? I was messing with the connector on the back of the switch before this started happening... |
underthetire |
Oct 31 2011, 10:09 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Probably. Get one from GPR, the cheap ones don't hold up.
WolfR32 |
Oct 31 2011, 10:18 PM
Probably. Get one from GPR, the cheap ones don't hold up. Hi Do you have a link? I was searching hereGPRparts but could not find anything. |
Cap'n Krusty |
Oct 31 2011, 10:23 PM
So I'm having a short or an open in the ignition wiring or something, when I turn the wheel left slightly the motor dies, if I turn it more its ok, right its fine... Any ideas? Ignition switch broken? I was messing with the connector on the back of the switch before this started happening... Perhaps you should think about asking a COMPLETE question, i.e., giving us enough information about your car, a Porsche, I presume, that we can get it together and give you a reasonably accurate answer. The Cap'n |
WolfR32 |
Oct 31 2011, 10:52 PM
So I'm having a short or an open in the ignition wiring or something, when I turn the wheel left slightly the motor dies, if I turn it more its ok, right its fine... Any ideas? Ignition switch broken? I was messing with the connector on the back of the switch before this started happening... Perhaps you should think about asking a COMPLETE question, i.e., giving us enough information about your car, a Porsche, I presume, that we can get it together and give you a reasonably accurate answer. The Cap'n I should have kept it simple... Can a broken ignition switch cause the car to stop when turning the steering wheel. I can not easily check the switch as there is a roll cage cross bar blocking the set screw (IMG:style_emoticons/default/headbang.gif) And yes its a 74 2.0 Porsche 914. |
dlestep |
Nov 1 2011, 06:38 AM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
...your car has the same disease my wife has. Under any circumstances,
when driving, she can only turn right. I was in a hangar at 10 Mountain, when I received a cell phone call from her. She said that she was lost. (She made two incorrect right turns). After listening to the cross streets, she was 32 miles SOUTH of where she was supposed to be. Her normal drive home is 7 1/2 miles. |
BigDBass |
Nov 1 2011, 07:24 AM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
You better listen to your friend Billy Zane. He's a cool guy.
sfrenck |
Nov 1 2011, 09:37 AM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Paint it brown and sell it to UPS (they aren't supposed to turn left).
Elliot Cannon |
Nov 1 2011, 12:01 PM
So I'm having a short or an open in the ignition wiring or something, when I turn the wheel left slightly the motor dies, if I turn it more its ok, right its fine... Any ideas? Ignition switch broken? I was messing with the connector on the back of the switch before this started happening... Perhaps you should think about asking a COMPLETE question, i.e., giving us enough information about your car, a Porsche, I presume, that we can get it together and give you a reasonably accurate answer. The Cap'n I pretty much assumed it was a Porsche 914 from looking at his avatar. It's that little picture just to the left. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/happy11.gif) |
SLITS |
Nov 1 2011, 01:12 PM
Sure you don't have the harness wires fouled in the steering linkage?
WolfR32 |
Nov 1 2011, 09:34 PM
Sure you don't have the harness wires fouled in the steering linkage? Thanks Ron, That is that type of response I was looking for. I will check and make sure I didn't get something caught when I was futzing with the ignition wiring. Thanks again! (IMG:style_emoticons/default/beerchug.gif) |
Mike Bellis |
Nov 1 2011, 09:44 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
What about a broken ignition lock binding in the column?
campbellcj |
I can't Re Member Group: Members Posts: 4,597 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Larry - don't mind the Krusty One - it's the first of the month and his crustiness quota just reset. (IMG:style_emoticons/default/wink.gif)
Have you checked the electrical part of the ignition switch for visible cracks? That's a fairly common failure mode. My first guess was the harness connector though, as Ron suggested. I hope it's something relatively simple and cheap...rollcages never make this kind of work easy (BTDT). |
Lo-Fi Version | Time is now: 4th January 2025 - 06:25 PM |
