2-OH! |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 ![]() |
1976 - 2.0
Just got the car back together, new clutch plate, pressure plate, T/O bearing, flywheel, terry cable, bushings and engine re-build...Pedal play is 1/2 to 3/4 inch... When I shift, I get momentary shudder in all gears (more pronounced in 1st, 2nd, lees in 3rd, less in 4th hardly noticeable in 5th) and the car lacks all it's power... Valves are adjusted correctly, F/I seems to be correct, no vacuum leaks that I can find... Any thoughts ??? 2-OH! |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Dribbeling injector.
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
So its the engine that shutters? Or something else?
If its something else, it could be the half shafts.... I know the 944 turbo "shutters" when its under large load. Andrew |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Motor mounts. (IMG:style_emoticons/default/wink.gif)
ematulac |
914 addict ![]() ![]() ![]() Group: Members Posts: 540 Joined: 24-November 03 From: Palmdale, CA Member No.: 1,382 ![]() |
I agree with Mark: check the motor/transmission mounts.
Mine is doing the same thing. When the shudder occurs, the shift lever also 'bounces' around, and the gas pedal seems to push itself in. The first time it happened I thought the car was possessed. (IMG:style_emoticons/default/unsure.gif) I just received some new mounts from JWest Engineering and am planning on replacing the old ones this week. I'll let you know if it fixes things. |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Motor and or tranny mounts.
Use 911 sport mounts in the rear for the tranny... 49.95 B |
2-OH! |
Can you look at the mounts and tell if they are good, bad or indiffererent...While I had the motor out, I cleaned and inspected the mounts...They look good, feel solid, no cracks or disbonding, not oil soaked...They feel solid...
How do you test/check em'... 2-OH! |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(2-OH! @ Aug 5 2004, 12:19 PM) How do you test/check em'... have someone put car in gear and disenage the clutch while you watch the engine. if the mounts are shot, it'll *jump* when it get's it's first hit of power ... (IMG:style_emoticons/default/wink.gif) Andy |
Lo-Fi Version | Time is now: 26th June 2024 - 05:25 AM |
