> 914-6 enrichment lever, the same as a 911?
morph
post Aug 8 2004, 01:00 PM
quality parts builder
basic question is the enrichment lever the same from a 914-6 the same in a early 911? the lever in front of the shifter for carbs.also does anyone have pictures of this set up ? they would like to share?
Eric_Shea
post Aug 8 2004, 01:50 PM
PMB Performance
No pictures but I have a 914-6 and an early 911.
The 914-6 utilizes a rod that runs forward to a specially stamped accelerator pedal bracket. Pushing the lever forward positions the rod against the bracket and basically pushes down the accelerator pedal.
The 911 utilizes a nylon cam that pulls the accelerator cable forward as you lift up on the lever (if'n I recall proper).
morph
post Aug 8 2004, 02:01 PM
hmmmm.... thanks for the info (IMG:style_emoticons/default/idea.gif)
- Lo-Fi Version Time is now: 4th January 2025 - 07:34 PM
