neyen14 |
Member ![]() ![]() Group: Members Posts: 67 Joined: 2-December 07 From: New Mexico Member No.: 8,408 Region Association: Southwest Region ![]() |
I am bout to put some fender flares on my '75 914, and I measured the bottom opening of the rf fender and it measures 27.5" inches... the left front measures 27.75"... same measurements on the '72 that I have. Is it just my 914's or everyone have that scheme goin on? (IMG:style_emoticons/default/WTF.gif)
Jeff Hail |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 ![]() |
I am bout to put some fender flares on my '75 914, and I measured the bottom opening of the rf fender and it measures 27.5" inches... the left front measures 27.75"... same measurements on the '72 that I have. Is it just my 914's or everyone have that scheme goin on? (IMG:style_emoticons/default/WTF.gif) Pretty normal. My car has about 1/2 difference side to side. The left rear quarter panel wheel opening is 5/8 larger than the right side. Like a mirror if you get really close you will see stuff you don't like. |
r_towle |
Use the rocker panel to center the flares
neyen14 |
Jeff Hail |
Use the rocker panel to center the flares I figured as much... I'm gonna use the front valance and the rocker panels as the guides. Both left and right side of the flares measure 27.5". Thanks for the feedback, mucho appreciated .... And once you get your flares centered and installed you will probably notice one rear wheel sits a little farther in than the other. You will freak out and do some more measuring thinking how could this be? Do my wheels have the same offset? Is one wheel a 1/4-1/2 inch narrower than the other? Then when you measure the inside wheel bead at the top horizontally to the inner wheelhouse you will think did Germans actually make this car? Yep they did and these cars are no where near close. Foley and I discussed this. Just ignore it and don't let the head demons get the best of you. |
neyen14 |
Use the rocker panel to center the flares I figured as much... I'm gonna use the front valance and the rocker panels as the guides. Both left and right side of the flares measure 27.5". Thanks for the feedback, mucho appreciated .... And once you get your flares centered and installed you will probably notice one rear wheel sits a little farther in than the other. You will freak out and do some more measuring thinking how could this be? Do my wheels have the same offset? Is one wheel a 1/4-1/2 inch narrower than the other? Then when you measure the inside wheel bead at the top horizontally to the inner wheelhouse you will think did Germans actually make this car? Yep they did and these cars are no where near close. Foley and I discussed this. Just ignore it and don't let the head demons get the best of you. Ai Yai I!!!One wheel is going to sit further in the the other one?! "Just ignore it and don't let the head demons get the best of you"? (IMG:style_emoticons/default/blink.gif) Thanks a lot for that heads up. Enjoy your holiday Jeff. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:46 AM |
