Replacing fuel lines, Not as easy as I tought |
mikea100 |
Dec 28 2011, 03:05 PM
Member Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
While replacing my fuel lines I noticed that they're metal from shifter lever going forward and plastic going back.
Here're my steps. First, I removed the fuel tank and noticed that fittings on the outside firewall are metal (Picture 1). Then I removed front tunnell access plate and the lines were metal (Picure 2). I thought that it was nice of PO to have them replaced. But when I removed rear tunnell access plate the lines were plastic. I wanted to trace the entire line and removed shifter lever and saw a some kind of connector that hooks up metal line to plastic (Picure 3). Is this stock setup? (IMG:style_emoticons/default/WTF.gif) I purchased a comlete set from Tangerine and those lines will replace everything firewall to firewall. However, I noticed that fittings (Picture 4) are much smaller than the ones that are there now (Compare Pic 1 to Pic 4). Should I be concerned sbout that? Happy New Year! (IMG:style_emoticons/default/beerchug.gif) Mike Attached thumbnail(s) |
bigkensteele |
Dec 28 2011, 03:30 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Too bad you removed the shifter. Re-adjusting will probably be more time consuming than replacing the lines.
Spray a little wd-40 on the metal lines up front and push them through the rubber grommet into the tunnel. Go to the back of the car and yank them out. You will find that the metal tubing is only about 2 feet long. The other ends are barbed and the plastic line is just shoved onto them - there are no clamps or connectors. Not sure what we are looking at in picture 3, but I think it might be the evap line from the charcoal cannister on the right, and maybe the speedo cable on the left. I don't think those are your fuel lines. for installation, watch this excellent video that Rotary'14 made... http://www.youtube.com/watch?v=hxFRQTWLetw |
Vysoc |
Dec 29 2011, 08:52 AM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Too bad you removed the shifter. Re-adjusting will probably be more time consuming than replacing the lines. Spray a little wd-40 on the metal lines up front and push them through the rubber grommet into the tunnel. Go to the back of the car and yank them out. You will find that the metal tubing is only about 2 feet long. The other ends are barbed and the plastic line is just shoved onto them - there are no clamps or connectors. Not sure what we are looking at in picture 3, but I think it might be the evap line from the charcoal cannister on the right, and maybe the speedo cable on the left. I don't think those are your fuel lines. for installation, watch this excellent video that Rotary'14 made... http://www.youtube.com/watch?v=hxFRQTWLetw Nice Video, not that hard. Doable with one person, very easy with two. Vysoc (IMG:style_emoticons/default/flag.gif) |
mikea100 |
Jan 5 2012, 09:02 AM
Thank you guys (IMG:style_emoticons/default/beerchug.gif) . I got sidetracked and installed front sway bar instead. One of those "while I'm at it" things (IMG:style_emoticons/default/biggrin.gif) . I also want to treat inside the tunnel, at least as much as I can reach.
pete000 |
Jan 5 2012, 10:32 AM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I am just a couple steps ahead of you. I thought the same thing when I saw the stock metal lines under the tank. Just the way Porsche did it. The plastic was high tech back then and cheap.
I left the shifter in doing the swap, but now I see in your pictures the lines are held down with tabs, Might have to double check mine make sure I have the lines going through there. (IMG:style_emoticons/default/idea.gif) I also did the front sway bar while I had the tank out. |
RiqueMar |
Jan 5 2012, 10:48 AM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Sorry if this is hijacking, but has anyone done this with AN fittings already fitted to the hoses? I have the SS lines, and am trying to wrap my head around how to install them after I put the fittings on.
ChrisFoley |
Jan 5 2012, 12:25 PM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Sorry if this is hijacking, but has anyone done this with AN fittings already fitted to the hoses? I have the SS lines, and am trying to wrap my head around how to install them after I put the fittings on. We weld -6 fittings on stainless lines for some customers. Installation requires the firewall thru hole size to be increased. We have an oversized grommet for this application. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:17 PM |
