Front hood scoop |
Front hood scoop |
Stonepilot |
Jan 4 2012, 02:07 PM
Newbie Group: Members Posts: 20 Joined: 6-December 11 From: Pensacola, Florida Member No.: 13,863 Region Association: South East States |
Anybody done one of these? Got a picture would love to see what it looks like? Thank you
SirAndy |
Jan 4 2012, 02:16 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Anybody done one of these? Got a picture would love to see what it looks like? Thank you Scooping for what exactly? (IMG:style_emoticons/default/confused24.gif) |
Stonepilot |
Jan 4 2012, 02:20 PM
Air across a radiator
wingnut86 |
Jan 4 2012, 02:21 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Stonepilot,
Are you thinking of just visual with a blocking plate in the hole or is this for oil cooling? The reason I ask is due to not many going top-scoop mount as it creates flow issues over that streamlined hood of ours (IMG:style_emoticons/default/blink.gif) Most AX'rs, Racers and Street Demons use a vented lower valance up front or something less visual. Good luck if you find something and please share it here, as I for one have never seen one... |
SirAndy |
Jan 4 2012, 02:24 PM
Air across a radiator The hood is too high for a intake scoop. Usually, you run the intake though a opening in and behind the bumper (See my avatar). There are several ways for the air to exit and i do prefer the "out the hood" vent. Neither the "original Porsche way" (out the bottom) as well as the "v8 way" (out the fender wells) appeal to me. The first adds a lot of hot air under the car, the second adds a lot of hot air onto the front brakes. Do a search here, there are several cars that have gone the exit out the hood route. It's crucial to have a front facing "lip" on the exit to help with air-flow. (IMG:style_emoticons/default/popcorn[1].gif) |
SirAndy |
Jan 4 2012, 02:27 PM
I'm currently venting out the bottom, but that's temporary until i can find the time to fabricate a nice shroud for venting out the hood.
http://www.914world.com/bbs2/index.php?s=&...st&p=893543 (IMG:style_emoticons/default/driving.gif) |
bfrymire |
Jan 4 2012, 06:32 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Look for Britain's build thread on adding a suby powerplant to the 914. He has a hood exit for the radiator using louvers.
-- brett |
JmuRiz |
Jan 4 2012, 07:16 PM
914 Guru Group: Members Posts: 5,443 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I'm currently venting out the bottom, but that's temporary until i can find the time to fabricate a nice shroud for venting out the hood. http://www.914world.com/bbs2/index.php?s=&...st&p=893543 (IMG:style_emoticons/default/driving.gif) Now you're talking...venting out the hood is the best way, as long as you don't mind poising cargo space. I'm trying to think of a way to do a front cooler w/o taking up much/if any cargo space up front...haven't found one yet though. |
SirAndy |
Jan 4 2012, 07:32 PM
I'm trying to think of a way to do a front cooler w/o taking up much/if any cargo space up front...haven't found one yet though. Look at some newer model Porsche's. They use a very steep angle right after the cooler that goes almost straight up. (IMG:style_emoticons/default/shades.gif) In my case, i'm going to make the shroud a two piece part so when you open the hood, you still have access to the space behind the shroud. Should be enough for a toolbox and other assorted items. The spare tire is already mounted in the rear trunk. I'm going to leave it a full-size spare but i'll be going down in rim diameter. Right now my spare is a 7" cookie cutter with a 215 tire. A 5.5" with a tire somewhere around 175 should be plenty for a spare. (IMG:style_emoticons/default/santa_smiley.gif) |
Stonepilot |
Jan 5 2012, 06:53 AM
could you raise the hood an inch up near the windshield and build a vent under the hood to take the air coming thru the radiator out over the windsheild. of course the air coming in is under the car. is the air coming off the radiator that hot?
Andyrew |
Jan 5 2012, 07:35 AM
What engine will you be running?
Stonepilot |
Jan 5 2012, 07:51 AM
Id like an EJ20 but any 6 will do, maybe something new
rnellums |
Jan 5 2012, 08:22 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
could you raise the hood an inch up near the windshield and build a vent under the hood to take the air coming thru the radiator out over the windsheild. of course the air coming in is under the car. is the air coming off the radiator that hot? The problem there is that the base of the windshield is a high pressure zone. It isnt as high as the front of the car where your inlet will be, but you won't get as much airflow as if you vent to a low pressure area. When I do my conversion I think I will vent to the wheel wells. I still need to do the calculations, but I think the relative heat coming out of the vents should be far less than the temperature of the brakes under heavy use. |
bulitt |
Jan 5 2012, 09:11 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Some pics-
Ferrari 308, 512bbi used louvered grills- Shelby Daytona- With lip Andy mentioned. Ford GT-40 Jag XKE used louvers, Dodge viper also louvers. |
brant |
Jan 5 2012, 09:22 AM
914 Wizard Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I've ran a vented hood on my oil cooler for 15 or so years
its all steel and pictured in my street car signature below |
Britain Smith |
Jan 5 2012, 12:55 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Vented Carbon Fiber Louvers...works awesome.
(IMG:http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash2/181041_1538642912578_1430063084_31131848_4143754_n.jpg) (IMG:http://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash2/179487_1538642992580_1430063084_31131849_4365397_n.jpg) -Britain |
SirAndy |
Jan 5 2012, 12:59 PM
I've ran a vented hood on my oil cooler for 15 or so years its all steel and pictured in my street car signature below That's exactly what i want to do! (IMG:style_emoticons/default/thumb3d.gif) Well, not the big hole in the hood, but what you had before that. A shroud going up with louvers on the hood for the exit. (IMG:style_emoticons/default/driving.gif) |
Stonepilot |
Jan 5 2012, 02:09 PM
very nice thats what I was talking about. thank you
Andyrew |
Jan 5 2012, 08:49 PM
With a small engine like that, you could put a small radiator in the front of the trunk, or in with the body and then exhaust it out the front of the hood like the new porsche's. Then guess what, You still have a front trunk!
wingnut86 |
Jan 5 2012, 09:01 PM
Lo-Fi Version | Time is now: 26th June 2024 - 10:09 AM |
