Lennies914 |
Slacker ![]() ![]() ![]() Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California ![]() ![]() |
So I've been preping my '75 for paint for the last two weeks and figured I was ready for primer. So I thought I'd do a quick wipe down with acetone and a tack cloth then shoot some primer. Had I been more experienced at painting I probably would have realized sooner that the paint (repaint) that I have been sanding on for two weeks was lacquer (IMG:style_emoticons/default/headbang.gif) . The acetone imeadiatly started washing off the old paint. So hear is my question. Is there anything better and cheaper than acetone to wash down the car? Assuming that I cannot paint over the lacquer with acylic urethane.
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
The other night you said you were going to wipe it with Mineral Spirits...what happened? (IMG:style_emoticons/default/drunk.gif)
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
Hi Lennie,
First off I need to say that I'm just a hobby painter, thought I've been doing bodywork for the past ten years when I first started working on cars in high school. So if any other more experience folks come along, I'd follow what they say. Ideally, we would want to remove all of that lacquer first. Urethane CAN be shot over lacquer, but long-term prognosis is not usually good. Are you just shooting 2K over the lacquer? You can use a product called Prep-Sol by DuPont, but being DuPont, it ain't exactly cheap. Most wax and grease removers sold at the FLAPS would work, I think. So you've already bought the primer? Acrylic? You'd most likely want to continue with lacquer for primer, color and clear, IMHO since thats whats on the car now. But, this depends on what kind of longevity you're looking for and how much you want to spend. I'm all about urethanes, especially in humid areas. Lacquer tends to absorb moisture over time - thats what its a bit outdated. So I've been preping my '75 for paint for the last two weeks and figured I was ready for primer. So I thought I'd do a quick wipe down with acetone and a tack cloth then shoot some primer. Had I been more experienced at painting I probably would have realized sooner that the paint (repaint) that I have been sanding on for two weeks was lacquer (IMG:style_emoticons/default/headbang.gif) . The acetone imeadiatly started washing off the old paint. So hear is my question. Is there anything better and cheaper than acetone to wash down the car? Assuming that I cannot paint over the lacquer with acylic urethane. |
ThePaintedMan |
The other night you said you were going to wipe it with Mineral Spirits...what happened? (IMG:style_emoticons/default/drunk.gif) You don't want to wipe with mineral spirits before applying acrylics or urethanes, right? |
Lennies914 |
Yes, I've already bought the paint and primer. As for the paint thinner, I just bought that for cleaning my guns.
It seems to me that I was always told not to spray urethane over lacquer. But I haven't painted in several years. Yes it is 2K. So I can finish cleaning the one fender with acetone (and re-prep it) then prime over it? |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Your paint job is only as good as what is under it. I don't paint over a re-paint. Bad things can happen. Strip off the laquer first. When you go to wipe down the car use Dupont 3812 or 3919S.
http://pc.dupont.com/dpc/en/US/html/visito...19295_3919S.pdf |
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
The thing is, the original paint was lacquer, too.
In California, you won't be able to use lacquer, or buy it, I should say. What you need is a "tie coat" to put between. |
Lennies914 |
Thanks guys, I'll be washing off the repaint tonight. |
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
Nathan, the original paint on our cars is baked enamel, not lacquer.
rick 918-S |
Nathan, the original paint on our cars is baked enamel, not lacquer. (IMG:style_emoticons/default/agree.gif) |
nathansnathan |
I haven't been able to find a reliable source to confirm either way - I had had read that it was Glasurit Lacquer, this on 914club, but then it wouldn't be the first time the doctor was not right.
http://www.914club.com/bbs2/index.php?showtopic=287242 I'd read that porsche (not Karmann) used different systems based on color, like the red was a single stage, the blue was base/clear, but this was 924-specific. |
ThePaintedMan |
I can't help confirm that either way.... well, either. But I do know that was a pretty common strategy for automakers back when. Some of their paints simply wouldn't work right as a two-stage, so many were single stage. I haven't been able to find a reliable source to confirm either way - I had had read that it was Glasurit Lacquer, this on 914club, but then it wouldn't be the first time the doctor was not right. http://www.914club.com/bbs2/index.php?showtopic=287242 I'd read that porsche (not Karmann) used different systems based on color, like the red was a single stage, the blue was base/clear, but this was 924-specific. |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
You need a wax and grease remover to wipe down with, do not use any type of solvent. That said, clean up the panel you wiped, make certain you sand out all of the wipe marks or they will haunt you, then prime and body work or seal and paint if it is where you want it.
Lennies914 |
Thanks for all the help guys.
I recruited my son to come over last night to help strip off the lacquer. After all, he is the one that wrecked my '74 and is responsible for me having to build a new car (IMG:style_emoticons/default/biggrin.gif) . With his help we were able to get the car back down to it's original paint, one more full sand, and a coat of primer. I'm really happy that I stripped it down, I was curious as to why it was repainted in the first place. It turns out that it was nothing more than a couple door dings and a small left rear corner repair. I'll get some pics up soon. |
Lennies914 |
Lennies914 |
![]() Two small runs, we'll see in the morning how it turned out (when I'm sober). (IMG:style_emoticons/default/beer.gif) |
jeeperjohn56 |
Member ![]() ![]() Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None ![]() |
That look's good Lennie, I might come by tomorrow, my car needs a drive in it to wake up. John (IMG:style_emoticons/default/driving.gif)
Jeffs9146 |
Lo-Fi Version | Time is now: 25th June 2024 - 11:04 PM |
