jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
for the record
Attached image(s) ![]() |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
Thanx Jim!
The SS wall is quite a bit thinner as well - maybe 50-60% less. |
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
How about compared to stock 1.8 HE's ? Must be a really big difference.
jimkelly |
pic
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
If my calcs are correct, Area of Ellipse = 2.143 x A x B, where A = short radius and B = long radius which results in:
Area = 634 mm2 for the SS HE Area = 546 mm2 for the stock HE The SS HE pipe area is about 16% larger than the stock HE area. Not bad. But then you loose some sealing area due to the thinner wall tubing. |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Just courious. I assume that the OD is the same, but can you check?
Lo-Fi Version | Time is now: 26th June 2024 - 01:42 AM |
