Scott S |
Small Member ![]() ![]() ![]() Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 ![]() |
Hi All -
I will be ordering a custom oil line for the discharge side of my -6 conversion, and just want to have my ducks in a row. Does anyone know the size of the discharge line fitting on the factory tank? is it a 26mm? Thanks very much - Scott S |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
You need to look at your tank to make sure. I had heard some of the tanks were different. My tank has two different sizes. 26mm (engine compartment access) connects to the long steel oil pipe that connects to the right(passenger) side of the engine case. 30mm (left rear fenderwell) connects to the aluminum pipe below the oil cooler.
Lo-Fi Version | Time is now: 25th June 2024 - 09:05 PM |
