webber, ID |
webber, ID |
underdog |
Jan 19 2012, 09:06 AM
Member Group: Members Posts: 82 Joined: 20-September 11 From: Mountain Home, AR Member No.: 13,579 Region Association: None |
Where do I find ID number on webber carb.?
Thanks again and again.......... |
BajaXJ92 |
Jan 19 2012, 09:19 AM
Extended Member Group: Members Posts: 2,146 Joined: 20-April 06 From: Prescott, AZ Member No.: 5,895 Region Association: MidAtlantic Region |
Each ID is stamped on the base of the carb where it mounts to the intake manifold. Fairly obvious if the carbs are clean.
Gint |
Jan 19 2012, 06:51 PM
Mike Ginter Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
And usually on the inside base if still mounted on your motor.
And Weber is one "b". |
Lo-Fi Version | Time is now: 25th June 2024 - 12:47 AM |
