yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
Anyone have a line on an affordable source for flywheel/clutch bolts and washers. I've got damn near $40 before shipping in my cart at Pelican with just these items. That makes my head spin for what in reality can't be more than $5 worth of stuff.
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
The ones for the pressure plate?
yeahmag |
Pressure plate allen head bolts and washers and the flywheel bolts.
billh1963 |
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States ![]() |
SLITS |
Hardware store ... metric section
Flywheel ... M12 X 1.5 ... 25 mm long Pressure Plate ... M8 ... 18 mm long |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
The 5 flywheel bolts are not considered to be replacement items, so it's unlikely you need them. If you do have to use replacements, they're not gonna be a hardware store item because they have a special serrated locking feature on the contact side of the head.
The Cap'n |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,997 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Yeah, hardware store stuff won't cut it for the flywheel bolts.
They're metric, have short heads, and have the locking teeth on the underside of the head that bite into the lock plate. Specialty stuff, so they cost more than regular bolts will. If yours actually do need replacing for whatever reason, you're gonna have to suck it up and pay for the real thing. --DD |
SLITS |
Locktite RED ... (IMG:style_emoticons/default/biggrin.gif)
yeahmag |
More out of principle. The teeth look OK. I do need one pressure plate bolt and washer. I'll see if I can source that at a FLAPS.
Thanks! |
SLITS |
Tomorrow I will check the stock on metric alen head fastners and see if I have the M8s for you.
I use regular hex head anyway. |
yeahmag |
Thanks!
Harpo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None ![]() |
These bolt are also most likely grade 10.9 or 12.9. It should be marked on the head. Hardware store bolts most likely will not be strong enough. Yes use locktite.
David |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,332 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Aaron,
Try Hillco in Garden Grove. They are on Western Ave, half block north of Garden Grove. Hillco specializes in automotive fasteners. Their number is: 714-657-7442 A terrific place and it's close to an offramp on the 22 |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:57 PM |
