JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
Yesterday while waiting on someone, I got bored and got out the owners' manual and was reading it.
In the Starting Engine section it says: "Before starting, depress the accelerator pedal fully and keep at full throttle until the engine runs. This applies when the engine is warm or cold and during all weather conditions." I have just been just turning the key without touching the pedal and it will start immediately. Am I doing it wrong? I am running stock 1.7 FI on my 73 teener. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Bullshit! I've never done it that way. Don't have to. I don't even get in the car. Just lean in the window, put it in neutral and turn the key.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,514 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) Yep
JawjaPorsche |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
Not to be contrary to the vaunted members above, but I've done it per the manual and that works best when trouble starting, although I agree that they will usually start without this.
My VW & Porsche trained mechanic on 914s since the 70's explained it, that the early ECUs & EFI used the pedal depressed to engage the cold start circuit, which then engages the cold start valve/5th injector when cold enough to be needed - which of course is often not needed. This is possibly more critical for CA smog rules 914s which were tuned leaner to meet smog tests back when they were still tested. So whatever works for your particular 914..... (IMG:style_emoticons/default/biggrin.gif) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,546 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
If you do that on a 74 or 75 with a 1.8L L-Jet system, you risk damaging the FI system. If the engine happens to backfire, you WILL warp the flap in the airbox and then it will stick, causing a mixture issue.
I have never heard of using full throttle to engage the cold start circuit. I was under the impression that it was controlled by the Thermo time switch. Meaning when it got cold enough, the system would inject extra fuel. Actually, now that I think about it, isn't holding it at full throttle supposed to be used to clear flooding? |
flipb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,734 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region ![]() ![]() |
Actually, now that I think about it, isn't holding it at full throttle supposed to be used to clear flooding? Wouldn't holding full throttle cause/risk flooding? On my 2.0 with 40mm carbs, I usually depress the pedal to the floor slowly, twice, then release... and press the pedal about 15% while cranking. Got to say, when I had the Weber Progressive, it was easier to start since it had electric choke. Pump once, release pedal, crank. |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Actually, now that I think about it, isn't holding it at full throttle supposed to be used to clear flooding? Wouldn't holding full throttle cause/risk flooding? Holding throttle wide open has always been the trick when flooded. Seems counter-intuitive because it is adding more fuel, but it's the extra air that it needs. Learned that trick for the dirt bikes when I was a kid. On the 914 I never hold the throttle to the floor when starting unless on a rare occasion if it doesn't want to start when warm. |
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
If you do that on a 74 or 75 with a 1.8L L-Jet system, you risk damaging the FI system. If the engine happens to backfire, you WILL warp the flap in the airbox and then it will stick, causing a mixture issue. I have never heard of using full throttle to engage the cold start circuit. I was under the impression that it was controlled by the Thermo time switch. Meaning when it got cold enough, the system would inject extra fuel. Actually, now that I think about it, isn't holding it at full throttle supposed to be used to clear flooding? ........... (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/shades.gif)(But... I see ahole mech. do it all the time)....I agree wit ya! |
Lo-Fi Version | Time is now: 19th June 2024 - 01:30 PM |
