JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
My steering was getting so bad on my teener that I felt like I was driving a old truck. Lots of play in the steering wheel. I pulled the gas tank and sure enough: The original steering coupler was toast. I order a upgrade coupler from Tangerine Racing: http://www.tangerineracing.com/steeringupgrades.htm
This product is less than half of a new OEM rubber coupler too! See the comparison of the old coupler with the new one. I have my go-cart steering back! Attached image(s) ![]() |
Chris Hamilton |
Senior Member ![]() ![]() ![]() Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 ![]() |
Nice to see someone makes these in one piece.
In the past I had to improvise by putting two of these in: http://www.mamotorworkstv.com/vw/product/308032/ |
gothspeed |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None ![]() |
Wow! Good looking part!! I knew there was a reason I had not reinstalled my fuel tank yet!! (IMG:style_emoticons/default/smile.gif)
913B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None ![]() |
My steering was getting so bad on my teener that I felt like I was driving a old truck. Lots of play in the steering wheel. I pulled the gas tank and sure enough: The original steering coupler was toast. I order a upgrade coupler from Tangerine Racing: http://www.tangerineracing.com/steeringupgrades.htm This product is less than half of a new OEM rubber coupler too! See the comparison of the old coupler with the new one. I have my go-cart steering back! Stupid question, on your picture what do you look for to see if it is good or bad, the metal sleeve part ? I have my rack out switching the front end out. Its been so long I dont even remember how the steering was on my car. |
jonferns |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States ![]() ![]() |
My steering was getting so bad on my teener that I felt like I was driving a old truck. Lots of play in the steering wheel. I pulled the gas tank and sure enough: The original steering coupler was toast. I order a upgrade coupler from Tangerine Racing: http://www.tangerineracing.com/steeringupgrades.htm This product is less than half of a new OEM rubber coupler too! See the comparison of the old coupler with the new one. I have my go-cart steering back! Stupid question, on your picture what do you look for to see if it is good or bad, the metal sleeve part ? I have my rack out switching the front end out. Its been so long I dont even remember how the steering was on my car. The holes around the metal sleeves are worn, you can see how large they have gotten in that picture; that will produce some sloppy steering. |
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
It may be possible to get this part cut down in thickness for the guys raising the rack for bump steer , otherwise you are pushing the steering shaft up into the cabin area more and have changed the geometry of the steering shafts . It may not make it harder to steer , but having the shafts in the original plane would help .
Great looking product . (IMG:style_emoticons/default/piratenanner.gif) Jack |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
It may be possible to get this part cut down in thickness for the guys raising the rack for bump steer... We sell them in two thicknesses. (IMG:style_emoticons/default/smile.gif) |
gothspeed |
^^ ........ cool! I have a 1973 and just added the standard weltmeister bump steer kit ....... so this 'thinner' one will just bolt right on??
nsr-jamie |
914 guy in Japan ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None ![]() |
This is not really a bolt on part....I mean it bolts on but to get to that point there is a lot of work. My steering and suspension was shot, I also ordered one from Tangerine (Chris F)...while I was installing this part I also added Turbo tie rods with the Lemforder pieces, new ball joints and the Weltmiester bump steer kit. All these parts combined completely transformed the steering of my car to a much more direct feeling and made driving so much more fun. Totally recommened !! I will have to say that though I did not actually install the parts myself, had my shop do it while we were doing the new shocks, front roll bar, tank restoration, bushings and new shocks all around with rear springs...they told me it was a lot of work and hoped to never do that again. If you do a search they are others who have done this upgrade and I think its worth it...my coupler was in bad shape too. Just be prepared for lots of work if you try it yourself or lots of money if you pay to have the work done like I did. Anyway the part is very high quality and helps a lot. I am so glad I had this done to my car.
JawjaPorsche |
While there is work in replacing this, it is not that hard. I am a 63 year-old shade tree mechanic.
I had play in the steering wheel as probably going to live with in until I heard horrible crunching sounds! When I got to the coupler I found out one of the bolts that bolts from the bottom of the coupler had gotten loose and came completely out! Thank goodness my hearing had not failed me at my age or I could be driving with only one bolt between me and oncoming traffic! The only help I had was having my wife to help me lift the gas tank out. Once the tank is out is you have to get to the coupler. It is covered by a plastic cover. The easiest way to remove the cover is get a razor cutter and slit the cover and remove it. (If you choose not to cut the cut the cover then you are in for a lot of work. I just put the cover back when finished and taped it up good. Doesn't look that good but hey who is going to see it!) Remove the two top bolts on the coupler. I then removed the two hex bolts on the bearing near the firewall and pushed the bearing down to the coupler about four inches. This allows you to rotate the steering shaft enough to get the bottom bolts of the coupler. The bolts have metal tabs bent over the bolts to keep from loosing. I replaced the bottom bolts with longer ones and added lock nuts. This might be overkill but made me feel good! See picture. Note: I tackled this project after getting help and encouragement from jmill and scotty b in this forum. Hope this helps, Terry. This is not really a bolt on part....I mean it bolts on but to get to that point there is a lot of work. My steering and suspension was shot, I also ordered one from Tangerine (Chris F)...while I was installing this part I also added Turbo tie rods with the Lemforder pieces, new ball joints and the Weltmiester bump steer kit. All these parts combined completely transformed the steering of my car to a much more direct feeling and made driving so much more fun. Totally recommened !! I will have to say that though I did not actually install the parts myself, had my shop do it while we were doing the new shocks, front roll bar, tank restoration, bushings and new shocks all around with rear springs...they told me it was a lot of work and hoped to never do that again. If you do a search they are others who have done this upgrade and I think its worth it...my coupler was in bad shape too. Just be prepared for lots of work if you try it yourself or lots of money if you pay to have the work done like I did. Anyway the part is very high quality and helps a lot. I am so glad I had this done to my car. Attached image(s) ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
good thread. did you clean your tank while it was out?
k |
JawjaPorsche |
gothspeed |
Thanks for the additional info Jawja!
Lo-Fi Version | Time is now: 26th June 2024 - 06:08 AM |
