> Glove Box, Trying to get the lock to work
jim_hoyland
post Sep 11 2004, 08:18 PM
Get that VIN ?
After getting a new key for the glove box, the lock worked perfect. Over time I ca no longer get the lock to work. Waht is the trick to this ???
post Sep 11 2004, 08:20 PM
Resident German
QUOTE(jim_hoyland @ Sep 11 2004, 07:18 PM)
sometimes, they rattle lose and you can't turn them anymore.
make sure the nut on the backside holding the lock is tight ...
(IMG:style_emoticons/default/wink.gif) Andy
jim_hoyland
post Sep 11 2004, 08:23 PM
Get that VIN ?
The lock nut is tight, the cam turns correctly when I turn the key. When the door is closed, the cam is hitting something.
post Sep 11 2004, 09:03 PM
Resident German
QUOTE(jim_hoyland @ Sep 11 2004, 07:23 PM)
there's not much play in there, maybe you bend the glove box door hinge?
it has a little tab that is supposed to hit the lock part when the lock is in closed position, if that tab is bent it might prevent the lock from turning ...
- Lo-Fi Version Time is now: 27th December 2024 - 01:01 AM
