How to pull Dash TOP, i need to do it tommorow AM |
Aaron Cox |
Sep 12 2004, 09:29 PM
hey guys...gimme some pointers. i need to take off the dash in the AM for it to go to mexico (IMG:style_emoticons/default/cool.gif)
gimme pointers, tips, and tricks. what do i need out of the arsenal of tools? thanks very much in advance! (IMG:style_emoticons/default/smilie_pokal.gif) |
SirAndy |
Sep 12 2004, 09:41 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
the top is fairly straight forward.
it's held down by plastic nuts, 13mm if i'm not mistaken. some are rather hard to reach. take off the gauge cluster and radio for easier access. (also remove the steering wheel) ... note: if you think you got all the plastic nuts and it's still not moving, you missed one! (IMG:style_emoticons/default/wink.gif) Andy |
Aaron Cox |
Sep 12 2004, 09:43 PM
great! now by chance you have a diagram showing where they all are at? so i dont miss any?
also, how long will this take me? |
vortrex |
Sep 12 2004, 09:45 PM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
will take 10 min if you know where they all are, tracking them down is the hard part.
boxstr |
Sep 12 2004, 09:49 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
There is a total of nine plastic and I have seen alloy nuts that hold the dash pad in place.
The most diffcult ones are those located behind the gauges. They are all 14mm nuts. CCLINSOLDLOTSOFSTUFF |
jim912928 |
Sep 12 2004, 09:50 PM
Senior Member Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I just put my dash back on today. There are 9 nuts all together that hold the dash top pad on. 3 of them go through the front of the dash frame and 6 of them come through the frame from the top. If you get up under there and look, you can easily spot them as the bolts that are attached to the dash are white plastic and the nuts should all be plastic also (10mm I think). If you have an extension and swivels they are not too bad to get out...just have to contort yourself under that dash to see them (take the lower pad off to give you more room.
The ONLY real tricky nuts here are 2...I SAID 2...that attach to the dash from under the instrumet pad. It is not obvious that they are there and if you didn't go there you'd be tugging and tugging and ultimate crack your dash pad. So, to get these you must remove the instrument cluster and you'll see them. Us an open end box wrench to then loosen and remove these. Once you have all these off just lift up and out and off it comes. If memory serves me...the 3 that run along the front of the dash frame are to the extreme left and right (between the side of the dash frame and the fresh air vents. The 3rd is about in the middle. Good luck! Jim |
Andyrew |
Sep 13 2004, 12:24 AM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
IMHO its the hardest thing on a 914 to remove for the first time....
9 plastic bolts... I spent 3 hours the first time I took it out... most of it was trying to figure why the heck it wouldnt come out.. |
michel richard |
Sep 13 2004, 08:16 AM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
I took one off on Saturday, too bad I did'nt read the thread, I would've posted a picture.
In any event, what I can confirm is that the nuts are all 13 mm plastic. There are two that hold down the back of the binnacle (for lack of a better word). |
rhodyguy |
Sep 13 2004, 08:33 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,193 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
start with removing the steering wheel, and glove box and door. iirc i had to pull the dash face vents too.
kevin |
jim_hoyland |
Sep 13 2004, 08:52 AM
Get that VIN ? Group: Members Posts: 9,561 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Can you post a picture of the dash cover showing the location of the nusts ? I'm getting ready to do same.
boxstr |
Sep 13 2004, 09:00 AM
Check the archives there was one posted not long ago.
CCLINWELLDOYOUFEELLUCKY |
Aaron Cox |
Sep 13 2004, 10:28 AM
(IMG:style_emoticons/default/rocking nana.gif) dude! you guys rock! (IMG:style_emoticons/default/aktion035.gif)
took all of 20 minutes to pull. i had to use a u joint a couple of times, and ratcheting box wrenches! (IMG:style_emoticons/default/beerchug.gif) 9 nuts all 13mm in size. did i mention this place rawks? (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/mueba.gif) |
Lo-Fi Version | Time is now: 27th December 2024 - 12:27 AM |
