oldschool |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,369 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California ![]() |
OK so I'm ready to drop the motor I got a copy of the bird list...on how to drop the motor....So I'm trying to remove the front motor mounts bolts, and they keep on spinning (IMG:style_emoticons/default/headbang.gif) how do I even get a wrench (IMG:style_emoticons/default/headbang.gif) in there.
..waiting for a answer (IMG:style_emoticons/default/beer.gif) |
'73-914kid |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California ![]() ![]() |
The motor mount bar that connects to the chassis right? Put a socket on top, and a wrench on bottom..and remove bolt.... (IMG:style_emoticons/default/av-943.gif)
Not sure what size, thee are are Jaime, but is gave me one heluva time, as both sides had different bolt head sizes... |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
It shouldn't be that hard! I use a offset wrench that has a bend at the ends and sits down into the U-bracket.
I have even gotten a short socket on it! |
oldschool |
The motor mount bar that connects to the chassis right? Put a socket on top, and a wrench on bottom..and remove bolt.... (IMG:style_emoticons/default/av-943.gif) Not sure what size, thee are are Jaime, but is gave me one heluva time, as both sides had different bolt head sizes... I KNOW THAT.... but how do I get one in there from the top ? |
Jeffs9146 |
The motor mount bar that connects to the chassis right? Put a socket on top, and a wrench on bottom..and remove bolt.... (IMG:style_emoticons/default/av-943.gif) Not sure what size, thee are are Jaime, but is gave me one heluva time, as both sides had different bolt head sizes... I KNOW THAT.... but how do I get one in there from the top ? You don't you have to do it from under the car! |
Jeffs9146 |
I like to just put the top wrench on while under the car and use an impact wrench to zip the bottom bolt off!
oldschool |
Just that I can't seem to find a good opening on the driver side?
Jeffs9146 |
Just set the wrench over the bolt up here and loosen from the bottom!
If you just cant do it you can remove the H/E to gain some room! PS: the one in this photo is upside down! I got it from the Pelican! Attached image(s) ![]() |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
..waiting for a answer http://www.914world.com/specs/tech_engdrop1.php (IMG:style_emoticons/default/driving.gif) |
sanddog |
Kim William Lane ![]() Group: Members Posts: 6 Joined: 6-November 11 From: Newcastle, WA Member No.: 13,757 Region Association: Pacific Northwest ![]() |
Just went through this Saturday when dropped my engine! For some reason all instructions I have seen don't say that there is a top nut ( 15mm ) that you have to secure with a wrench while turning bottom 14mm bolt outboard engine mount connections You got to have the wheels off and get your head up there or else do it by braille. Helps to have extra set of hands.
I also secured the engine mount bar with a jammed in 2x4 to keep it from falling when last bolt out, its is a little heavy. Got my engine out with only that as an issue and everything disconnected except for the a long ground strap to chassis. Somehow overlooked that. Good luck! |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Just set the wrench over the bolt up here and loosen from the bottom! If you just cant do it you can remove the H/E to gain some room! PS: the one in this photo is upside down! I got it from the Pelican! That is the way the bolt is susposed to be. It keeps the nut and the threads from getting buggered up when you run over something. |
etcmss |
etcmss ![]() ![]() Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest ![]() |
a deep socket on the top with ratchet and a combination or ratchet-socket on the bottom. Not that hard to get access. Its the cold floor.
Gary |
oldschool |
(IMG:style_emoticons/default/lol-2.gif) cold floor..its raining and cold in Pomona...thanks so much all, I had to pull the tin from the side to get a socket in but i did (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
QUOTE If you just cant do it you can remove the H/E to gain some room! I have found it is always easier to remove the engine AFTER removing the exhaust. Where do you think half of all the dents & scrapes on the HE comes from? Trying to remove the engine with it still attached. Stu |
SirAndy |
the one in this photo is upside down! That is the way the bolt is susposed to be. It keeps the nut and the threads from getting buggered up when you run over something.(IMG:style_emoticons/default/agree.gif) Bolt head on the bottom gives you more room ... (IMG:style_emoticons/default/smash.gif) |
Jeffs9146 |
the one in this photo is upside down! That is the way the bolt is susposed to be. It keeps the nut and the threads from getting buggered up when you run over something.(IMG:style_emoticons/default/agree.gif) Bolt head on the bottom gives you more room ... (IMG:style_emoticons/default/smash.gif) I am sure you are right!! (IMG:style_emoticons/default/first.gif) I have seen it both ways! (IMG:style_emoticons/default/beerchug.gif) It is a bit harder to install the motor that way. If you do it with the bolt head on top you can just jack the motor onto the bolt and thread on the nut. |
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
This is going to sound obtuse... but why is this so hard? I did mine in a little over 2 hours and that was mostly just to stop and document with photos. Not sure what you're doing different? (IMG:style_emoticons/default/confused24.gif)
914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
I dropped one qlast weekend and the bolt was so rusty I had to cut the mount holder, but in my case the tub is shot and oi will cut it up anyway
oldschool |
This is going to sound obtuse... but why is this so hard? I did mine in a little over 2 hours and that was mostly just to stop and document with photos. Not sure what you're doing different? (IMG:style_emoticons/default/confused24.gif) Not hard, just the first time for me....the one bolt (driver side) I wasn't sure how to get the socket in there. (IMG:style_emoticons/default/idea.gif) but thanks to uall...its done. Attached thumbnail(s) ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/thumb3d.gif) And just like the rest of us, now that you've done it once you too are an expert. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 09:44 PM |
