Turn signal indicators |
biker bob |
Feb 28 2012, 01:53 PM
Member Group: Members Posts: 53 Joined: 25-March 09 From: Eureks Springs Ar. Member No.: 10,200 Region Association: Southwest Region |
72 2.0L Turn signals work properly however the turn signal indicator lights flash once or twice and stop flashing. Help needed.
mrbubblehead |
Feb 28 2012, 02:05 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
markb |
Feb 28 2012, 05:02 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Yup, relay.
FlatSix |
Feb 29 2012, 03:39 PM
English Member Group: Members Posts: 191 Joined: 14-January 03 From: Poole, England Member No.: 144 |
Not necessarily the relay. I've just fallen for that and purchased a new relay which made no difference at all. I now believe it is voltage drop in the indicator circuit. When the weather warms up I'll investigate further.
gothspeed |
Feb 29 2012, 03:53 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Not necessarily the relay. I've just fallen for that and purchased a new relay which made no difference at all. I now believe it is voltage drop in the indicator circuit. When the weather warms up I'll investigate further. That would be good to find out! I have an indicator that will not flash ..... I replaced the flasher relay with no effect ... (IMG:style_emoticons/default/sad.gif) |
SirAndy |
Feb 29 2012, 04:22 PM
Resident German Group: Admin Posts: 41,711 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have an indicator that will not flash ..... That's a different scenario ... When the relay goes bad, the indicator light will flash once or twice and then *both* lights will flash, albeit very dim. In some cases, reving the engine above 2500 rpm will "bump" the relay and the indicator light starts flashing correctly. If you do not have any indicator lights at all, i would suspect something else besides the relay. (IMG:style_emoticons/default/shades.gif) |
914itis |
Feb 29 2012, 04:42 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I have an indicator that will not flash ..... That's a different scenario ... When the relay goes bad, the indicator light will flash once or twice and then *both* lights will flash, albeit very dim. In some cases, reving the engine above 2500 rpm will "bump" the relay and the indicator light starts flashing correctly. If you do not have any indicator lights at all, i would suspect something else besides the relay. (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/agree.gif) Did you replace the wiring harness? |
904svo |
Feb 29 2012, 05:49 PM
904SVO Group: Members Posts: 1,119 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Make sure that all the bulbs are good and the correct ones, the condition you describe can be cause with the wrong bulbs installed or one burn out.
Lo-Fi Version | Time is now: 29th June 2024 - 07:32 AM |
