Quick question, dont ignore me |
MattR |
Sep 13 2004, 09:56 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
Can anyone tell me what holds on the shroud around the steering column?
qa1142 |
Sep 13 2004, 10:03 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Housing is one piece. You have to pull column and take guts out. From what i hear, it is easier to just get a newer column than to fix them. Early 70-71 are hardest to work on
Aaron Cox |
Sep 13 2004, 10:09 PM
so there is now way to take the "shroud" off
sj914 |
Sep 13 2004, 10:12 PM
Senior Member Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
You can't take apart the shroud, but you can take the stuff out of the shroud. (IMG:style_emoticons/default/wacko.gif)
Dr Evil |
Sep 13 2004, 10:19 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Shroud is held on by one bolt under to the left. You can remove everything from it and then slide it off.
HTH |
Aaron Cox |
Sep 13 2004, 11:25 PM
QUOTE(Dr Evil @ Sep 13 2004, 09:19 PM) Shroud is held on by one bolt under to the left. You can remove everything from it and then slide it off. HTH thanks |
maf914 |
Sep 14 2004, 10:59 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I've had mine apart a couple of times for replacement of the ignition switch. Follow the Haynes manual procedure for steering wheel and column removal, page 105. It won't be very clear when you begin, but you can figure it out. When you finish it still won't be clear. (IMG:style_emoticons/default/laugh.gif)
aircooledboy |
Sep 14 2004, 02:44 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
QUOTE Follow the Haynes manual procedure for steering wheel and column removal, page 105. It won't be very clear when you begin, but you can figure it out. When you finish it still won't be clear. Amen to that brother. (IMG:style_emoticons/default/laugh.gif) Try this link:Bird ignition switch article Was pretty helpful to me. |
Dr Evil |
Sep 14 2004, 03:38 PM
I'll do one better for ya. Here is the bottom view of a removed steering column. You can see the single 8mm(?) bolt that holds it on.
Attached image(s) |
Dr Evil |
Sep 14 2004, 03:41 PM
After you remove the guts (4 screws that hold in the switch assemblies), and remove the cover for the ignition switch you can slide the collar off of the shaft. In the picture is my bearing as well, but you dont need to remove this unless there is a reason.
Attached image(s) |
Dr Evil |
Sep 14 2004, 08:45 PM
don't touch the bearing, you don't need to. Did you remove the ignition switch? If yes then just tug on it. It is hard to get off. Just wiggle it back and forth. It is an interferance fit at this point.
HTH |
Aaron Cox |
Sep 14 2004, 08:46 PM
it came off. what a PITA. cleaned it up, looks like new (gloss black)
thanks for your help |
Dr Evil |
Sep 14 2004, 08:55 PM
What, are you copying me punk?!
Aaron Cox |
Sep 14 2004, 11:42 PM
QUOTE(Dr Evil @ Sep 14 2004, 07:55 PM) What, are you copying me punk?! no. youre copying me! It looks better than new now! thanks for the idea! p.s. : hows "the stuff" ? |
redshift |
Sep 15 2004, 12:03 AM
Dood, NOTHING looks better than new, you should have seen these things when they were new... it's fun to walk down a row of ones that smell new.
oh jeees... wow.. m |
Dr Evil |
Sep 15 2004, 12:07 AM
uh, what stuff? (IMG:style_emoticons/default/confused24.gif)
This stuff? (IMG:style_emoticons/default/smoke.gif) Shhhh, I'll have it for you this weekend. |
Lo-Fi Version | Time is now: 27th September 2024 - 03:26 PM |
