r3dplanet |
Senior Member ![]() ![]() ![]() Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None ![]() |
Komeraden,
I'm trying to get my engine back into the car following a D-Jet-Do-Over that was my winter project. I'm having a having a hell of a time finding some difficult to source parts, and I'm wondering if anyone can chime in. Most of these cross reference as VW parts, but every online or local air-cooled VW shop I've tried shows no stock. Here's my list: Air cleaner bracket plugs for 1.7L, part # 020 022 3 (qty 5) (+2 for misc engine tin) J-Tube sheet metal grommet (bushing), part # 021 119 627 (qty 2) Cold star injector gasket for 1.7L plenum, part # 022 133 075 Alternator wiring harness engine sheet tin grommet, part # ??? (I don't see this part in the parts diagrams, but it measures 32mm for the groove diameter, and the wires measure perhaps 13mm for the inside diameter). In searching the forums I've seen other express a desire to find some of these bits, but I haven't seen any secret stashes. Thanks, Marcus |
ellisor3 |
HPWhore ![]() ![]() ![]() Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States ![]() ![]() |
Did you try the Bird??
http://www.pelicanparts.com/cgi-bin/ksearc...;FILTER_TOOL=ON These guys are local for me but they do ship as well. Carry most anything that is rubber: http://www.hechtrubber.com/Catalog/Pages/Page-44.htm |
r3dplanet |
Yes. Pelican alerted me that the fuel injector gasket is no longer available from the Porsche warehouse in Germany. The other parts don't even register.
ellisor3 |
Might also try DC Auto, but being that these are plugs grommets and gaskets, they may not be in the best shape.
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,185 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Komeraden, I'm trying to get my engine back into the car following a D-Jet-Do-Over that was my winter project. I'm having a having a hell of a time finding some difficult to source parts, and I'm wondering if anyone can chime in. Most of these cross reference as VW parts, but every online or local air-cooled VW shop I've tried shows no stock. Here's my list: #1 Air cleaner bracket plugs for 1.7L, part # 020 022 3 (qty 5) (+2 for misc engine tin) #2 J-Tube sheet metal grommet (bushing), part # 021 119 627 (qty 2) #3 Cold star injector gasket for 1.7L plenum, part # 022 133 075 #4 Alternator wiring harness engine sheet tin grommet, part # ??? (I don't see this part in the parts diagrams, but it measures 32mm for the groove diameter, and the wires measure perhaps 13mm for the inside diameter). In searching the forums I've seen other express a desire to find some of these bits, but I haven't seen any secret stashes. Thanks, Marcus #1 Do you have a pic ? #2 is available new from busdepot, but they are = to the OE pieces and deteriorate rapidly (IMG:style_emoticons/default/sad.gif) #3 ? is that a rubber piece? #4 If you cant find it new, I have several used (IMG:style_emoticons/default/bye1.gif) |
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
Auto atlanta is actually the cheapest place to get #1, the plugs for the air cleaner base
http://www.autoatlanta.com/Porsche-Rubber-...-GN0200223.html Germany Supply has them for .40 more apiece. I got some repros of #2 the air tube through the tin grommets off ebay but they are so thin it's pathetic. Better solution is to modify on of the rubber couplers for plumbing. The 1 1/2" size I think it is. The recesses for the clamps on the od fit snugly in the holes in the tin and the id is a good fit for the tubes. (IMG:http://www.914world.com/bbs2/uploads_offsite/plastic-plumbing-fittings.besttoyou.info-11782-1330559096.1.jpg) |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,208 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
Mikey914....914rubber,com. makes an engine grommet kit.
I am pretty sure he has the j tube grommet. |
r3dplanet |
r3dplanet |
I saw that German Auto in Canada had the plugs, but nearly $5 each. That's okay, but they're out of stock according the e-mail from them.
Confirmed. 914rubber.com has the J-tube grommets, but not a whole kit just yet. I spoke a little with Mark about this a while ago. The future looks bright. Mikey914....914rubber,com. makes an engine grommet kit. I am pretty sure he has the j tube grommet. |
Lo-Fi Version | Time is now: 21st June 2024 - 02:30 PM |
