ruddyboys |
Hummel eigentümer ![]() ![]() ![]() Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States ![]() |
I had a test drive and after a few miles the car stalls with fouled plugs again. I have dual Weber 40 IDFs with an 009 dizzy and an after market coil from my FLAPS. The timing is right on and the dwell is fine. After cleaning the plugz away I go for a few more miles. Idling they even foul after a few minutes. If I start turning the idle mixture screw out I start to get poping thru the tail pipe, which sounds like a lean condition, but after a few minutes the car stalls with fouled plugz. The car really hasn't idle very smooth. Could the pump by-pass valve be the culprit? I had this thread before and still can't get the car to run right.
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
1st - what kinda of fuel pump?
2nd - Do you have a regulator in line? Street carbs - 3.5 to max 5 psig You may be over-riding the float valves and flooding. |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Prolly not jetted right, too....
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Pump bypass valve? Not sure what that is.
It can still be an ignition problem. What plugs are you running? |
ruddyboys |
The by-pass valve is the valve at the bottom of the fuel bowl. I have a new rotary fuel pump from CB that has a built in regulator. (I do have a facet laying around somewhere). I an running Bosch plugz. My jets are Main = 115, Idle = 50 not sure of the air.
lapuwali |
Which Bosch plugs? The exact model (the heat range is important).
If you watch your engine running with the aircleaners off, do you see fuel coming out of the accelerator pump nozzles while idling? |
ruddyboys |
I have to check both those questions
tommy914 |
Life is a journey, enjoy every turn. ![]() ![]() ![]() Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None ![]() |
QUOTE(ruddyboys @ Sep 20 2004, 06:54 PM) If I start turning the idle mixture screw out I start to get poping thru the tail pipe, which sounds like a lean condition, but after a few minutes the car stalls with fouled plugz. Turning the idle mixture screw "out" makes it richer. Have your tried following one of the guides at aircooled.net on how to set up your webers? That would be a starting point.(after you make sure you have correct fuel pressure) |
MJHanna |
Does this 911 make my butt look big? ![]() ![]() ![]() Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 ![]() |
Have you synchronized the carbs? What size engine is this?
ruddyboys |
The engine is a 2056 ('originally '70 1.7). I have tried to sync the carbs and actually get pretty close.
914Timo |
******* ![]() ![]() ![]() Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe ![]() |
QUOTE Have you synchronized the carbs (IMG:style_emoticons/default/agree.gif) Synchronizing can make miracles. But, you are right. Carbs are from (IMG:style_emoticons/default/bootyshake.gif) |
Red-Beard |
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None ![]() ![]() |
I love carbs, but I'm doing the "Atkins" thing right now, so they are evil.
Oh, wait... (IMG:style_emoticons/default/burnout.gif) |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,341 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Carbs are not that tough, sounds like your jets are fine for that sized engine. Other things to consider as mentioned would be the plugs. If you are using Bosch, a heat range of 7 should be about right for a driver.
Also as mentioned, you don't need more than 3.5lbs of fuel pressure. Anything more isn't needed as long as your pump can keep up. It is easy to out "force" the floats. It sounds like you are close, keep at it. You may also be getting weak spark. Sounds corny, but grab a stock coil or one of the 0012 coils and see if that makes a difference. (IMG:style_emoticons/default/wink.gif) |
ruddyboys |
I was reading the How to jet your carbs article from Aircooled.net and at the end they say that the accelerator pump could be suppling to much fuel. You can turn the pump screw to adjust. I found a pic of the new Weber 40 IDf and were the adjustment nut is. Problem is I have the old version with the roller, were is the adjustment on these suckers. (IMG:style_emoticons/default/confused24.gif)
lapuwali |
You can change the pump jet itself, as well. I think this is what you're calling the bypass jet.
It's not uncommon, particularly with the roller types it seems, to have the pump nozzles dribble some fuel even with the throttle closed. If you look down the throat and see some fuel coming out of the nozzles, pull up on the linkage to force the throttle to be completely closed. If the dribbling stops, your linkage is holding the throttle slightly open (or you have the throttle stop open too much), so adjust as necessary. The nozzles are held into the bodies with screws that, if loose, will also cause some dribbling. If you can stop the dribbling by closing the throttle stops, but that causes the idle to be too low, then use the air bypass screws to add a bit more air. If you can't stop the dribbling by adjusting the throttle stop or linkage, then you may have to grind down the cam a touch to add clearance at the roller. This is a last resort, obviously. Once you take some off the cam, you can't add it back, and I have no idea if these cams are available as separate parts. As others have noted, if you've been turning the idle mixture screws OUT to adjust, you're making it richer, not leaner. Turn them all the way in until they're lightly bottomed, then out 2.5 turns. With the engine running, turn them in until you the engine starts to stumble, then back out 1/4 turn. You're now at the lean end of idle. If you have to turn them out more than 2.5 turns from bottomed to get a good idle, your idle jets are too lean. If you have to turn them in more than 1 turn from bottomed, your idle jets are too rich. Since you have 50 idles in there, they're not likely to be too rich until you have fuel leaking out from somewhere else. |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
First you must throw that shitty distributor away. Get a stock 205 Dizzy for a 1.8 or 2.0 engine. Put some sort of magnetic or optical pickup in it (Pertronix or Compufire). Leave off the vaccum can (it can be run as a centrifigal advance).
Toss the Bosch Plugs in the garbage and get a set of NGK B7ES plugs, you might even try a set of B6ES to get the car tuned. You must then go through the standard procedure for setting the carbs up as listed here: http://www.inglese.com/tech.htm. Once your carbs are synced you MUST make sure they are opening at the same rate and the same amount. I spent several hours on just making the linkage open each carb at exactly the same time. The more time you spend getting this perfect the more enjoyable the drive will be. My car drove like my stock injected Honda when I was driving it everyday. Set the valves first before you do anything else. I use the procedure: Bring #1 up to TDC adjust #1 INT & EXH, #2 intake, #4 Exhaust Rotate the engine 180 degrees to TDC on #3 Adjust #3 INT and EXH and #2 Exhaust. Set them all intakes to .005 and exhaust to.006 90% of carb problems are found in the Dizzy. I would start the car and bring it to operating temp, and start making carb adjustments. |
tommy914 |
QUOTE(Brett W @ Sep 21 2004, 01:06 PM) Set the valves first before you do anything else. I use the procedure: Bring #1 up to TDC adjust #1 INT & EXH, #2 intake, #4 Exhaust Rotate the engine 180 degrees to TDC on #3 Adjust #3 INT and EXH and #2 Exhaust. Set them all intakes to .005 and exhaust to.006 Brett, Have you had trouble with #4 intake when using this method? (IMG:style_emoticons/default/laugh.gif) |
Brett W |
Nope 17k Miles without a single problem. Too bad I wrecked the car.
tommy914 |
uhhh.... your instructions don't include #4 intake (IMG:style_emoticons/default/biggrin.gif)
Brett W |
You mean they didn't tell you about this secret when you bought your 914? I thought everyone knew about this. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
Number four never gets adjusted (IMG:style_emoticons/default/happy11.gif) Sorry I left that one out. Adjust number four intake when you do #3int and exh, #2 exhaust, #4 intake. |
Lo-Fi Version | Time is now: 26th June 2024 - 06:09 AM |
