4 Pages V  1 2 3 > »
> Rear Trunk Cable Release, Pop your trunk from inside the car
Engman
post Sep 21 2004, 05:14 PM
Zoisite
This mounts the release below the E-brake handle. Everything you will need is included. A cover for the release in the trunk is also provided. Please see http://engmanparts.com for details
Engman
post Sep 21 2004, 05:16 PM
Zoisite
A look at the mechanism.
aylanco
post Sep 21 2004, 07:44 PM
Dumb question that may have already been answered: Will this work if your trunk is locked?? (IMG:style_emoticons/default/unsure.gif)
Engman
post Sep 21 2004, 07:51 PM
Zoisite
This is really for the rear reflector that so many of us have added. It can be used with the stock trunk pushbutton lock - but the lock will not function. In other words if you lock the rear trunk it will still open by pushing the button inward, with this cable release installed. I have done this.
M
MattR
post Sep 23 2004, 09:09 PM
Does this mean you can shave the rear trunk button (and still open the trunk)?
dlo914
post Sep 23 2004, 10:46 PM
Whatchu' lookin' at?!?!
similar question about the shaved trunk button, ive taken out the button and filled up that center portion between the rear lights with that red transparent panel that displays Porsche, so the question is will i be able to open the trunk front within the cabin?
Engman
post Sep 24 2004, 05:00 PM
Zoisite
Yes - this is what this was designed to do. There used to be an electric solenoid kit that was made to do this. I have two of these and have not been able to make them work 100% of the time - usually wind up having to depress the trunk and hit the solenoid button many times to get this to work. I have tried using a relay with direct connection to the battery with 10G wire to no avail. Finally, I decided to develop a reliable option. All new mounting brackets and a cover to make sure that the actuator cannot be jammed from inside the rear trunk.
M
Carlitos Way
post Dec 25 2004, 07:49 PM
I did it MY WAY
Any pictures of this installed?
Engman
post Jan 3 2005, 01:37 PM
Zoisite
Here are pics of it in my 73.
Trunk
M
Engman
post Jan 3 2005, 01:39 PM
Zoisite
Pull handle for the release - located under the E-brake
M
mk114
post Mar 29 2005, 05:41 AM
LOST in NO space (my garage)
I know this is off the subject But I am a long time admirer of the 914 (15 +years) but only been a owner about 1 yr I have this cream puff of a body but some one drilled holled for this reflector I was wonder where do I get one (heard 911) but if this is right what year. How do I install it . Does it require electrical? Where can I get one of those trunk releases also?
jim_hoyland
post Mar 30 2005, 02:50 PM
Get that VIN ?
Looking at your trunk picture: Is the cable entering the trunk directly beneath the mechanism ?
How is the cable fed to the cabin mount ?
I like your set up !
Engman
post Mar 30 2005, 05:01 PM
Zoisite
The cable follows the witing harness for the tailights thru the engine compartment, exits thru a hole below the engine lid release, and come out under the e-brake handle. You do have to drill some holes for the cable and cable mount pull. This is all in the instructions with a template for drilling the release pull mount.
Mark
jim_hoyland
post Mar 31 2005, 09:57 AM
Get that VIN ?
I like the set up; does the installation require the engine be removed ?
Engman
post Mar 31 2005, 11:27 AM
Zoisite
Nope - pretty simple to install - about 45 mins or so.
I have like 10 of these left from the last run. When they are gone - they will be gone.
M
Kevin Phillips
post Apr 3 2005, 03:49 PM
I bought this and it went in in about 25 minutes. Very slick!!
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
This guy, Sorry I can't remember your name, ROCKS!!!!
kp
mpjedi23
post May 11 2005, 12:41 AM
Anyone have an extra porsche reflecter they willl part with (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif)
41ghost
post Jun 23 2005, 11:29 AM
i would like to get a couple of these you can email me at Dreamzwvr@aol.com or call 1-317-431-3621 ask for Drew thanks
Engman
post Jun 28 2005, 02:56 PM
Zoisite
Just a few left..... Don't say I did'nt warn ya....
M
Engman
post Jul 3 2005, 03:03 PM
Zoisite
2 remaining....
M
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 23rd November 2024 - 07:32 PM
