need to do a clutch today, can I do it w/out removing the trans? |
ottox914 |
May 25 2012, 06:27 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Been a bit since the last time I did a clutch IN a car. I seem to recall hearing of doing one w/out taking the trans out. I'd rather not have to do that, as removing the exhaust, turbo bits, and trans adds a lot more work. Ant thoughts or hints/tips? Its just me in the garage today, so hopefully I can get this done for the weekend.
r_towle |
May 25 2012, 06:38 AM
Custom Member Group: Members Posts: 24,645 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
nope, it needs to come out.
rich |
URY914 |
May 25 2012, 06:40 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 123,967 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You could leave the trany in but it would be the first time it will have ever been done.
Dr Evil |
May 25 2012, 06:41 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Wow, it would be the first time I have heard of it and I dont think it can be done.
Dr Evil |
Actually, ya you can leave the tranny in, but you will have to remove the engine to get to it (IMG:style_emoticons/default/wink.gif)
r_towle |
May 25 2012, 06:43 AM
I suppose if you have some training in magic it might be done.
The issue is behind the tranny...you will hit the underbody before you pull it back far enough to remove the input shaft from the pressure plate... If you have enough room behind it, you may be able to pull it all the way back, but you need to get that shaft all the way out of the pressure plate before you can remove the pressure plate.... So, while it might be done...with magic, it is faster to remove the tranny without magic and go from there. If you still have the underbody heat shield in place over the muffler, that is where you will hit. If that has been removed at some point, you might be able to do it. rich |
Luke M |
May 25 2012, 06:44 AM
Senior Member Group: Members Posts: 1,394 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Every clutch job that I've done in a 914 I had to remove the trans. Just support the engine w a jack n stands. Once I got the engine low enough I put 1 jack stand under each side of the engine then put a 2x6 across the headers to support the back of the engine. I've removed several trans in my 914 by myself in my younger years. Yes, two people make the job alot easier for sure.
Cap'n Krusty |
May 25 2012, 08:08 AM
It CAN be done without removing the tranny from the car. I've seen it done by pulling it back and letting it hang by the axles, laying on the HEs. The guy doing it believed it was faster, but I'm not so sure. Still, under an hour IS pretty good time.
The Cap'n |
dakotaewing |
May 25 2012, 08:54 AM
Senior Member Group: Members Posts: 1,163 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Wouldn't it be faster to drop the entire drivetrain and change the clutch once dropped?
rjames |
May 25 2012, 10:24 AM
I'm made of metal Group: Members Posts: 4,143 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
QUOTE It CAN be done without removing the tranny from the car. I've seen it done by pulling it back and letting it hang by the axles, laying on the HEs. Please don't let anything rest on the heat exchangers. That's a good way to pull an exhaust stud. Just take the trans out, it's not that difficult. Plus you can get a look at the throwout bearing while your in there. Pelican has a great step by step with pics. |
pt_700 |
May 25 2012, 10:33 AM
Senior Member Group: Members Posts: 1,100 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
although it's been awhile for me too, i agree with several posts above. that tranny has to come out. i was able to allow the engine to tilt slightly down in the back to get enough clearance to separate the tranny.
ottox914 |
May 25 2012, 03:12 PM
I've had an engine and trans out more times than I care to recall, between my car and the other "friends" I have that "invite" me over to play cars at their place.
I was hoping this would be a quick deal, but, yea, whatever. Between the kerry hunter header and turbo system, I "think" I can get the trans out w/out needing to dismantle the header and turbo bits. Dr. Evil- check your PM's. |
Dr Evil |
May 25 2012, 03:44 PM
Dave, reply sent. Lets do this! (IMG:style_emoticons/default/happy11.gif)
ottox914 |
May 29 2012, 02:47 PM
Just gave in and pulled the trans after taking some of the turbo stuff off. Exhaust stayed on, but just didn't the weight of the trans on the kerry hunter system thats in there. On a stock exhaust you'd have support at both sides from both HE's, but, well, it just looked a little scary. But not as scary as the pressure plate.
What?!?!?!?! Called the mfg, PP has been sent back to them. Can't have 1500 miles on this. Can't imagine I didn't see this when it was installed. Can't imagine what broke to cause this condition. Soooo slipping clutch due to whacked PP, not contaminated or grenaded clutch disc. Results and costs following the teardown of the PP will determine the scope of the "while I'm in there" part of the project. Being still sub-optimally employed, (no job) what little $$$ I have hidden away had to go a bit farther than when the black ops fund was receiving bi-weekly assistance... Anyone with thoughts on this? And- the clutch disc I pulled out was a factory 6 spring. I had another factory 6 spring NIB that I pulled out to compare to the one that was in service. They were pretty identical, except that the center, splined section was maybe 1/4" longer on the NIB clutch disc. Both are Sachs. Any problem using either disc in the car? Attached image(s) |
Cupomeat |
May 29 2012, 02:55 PM
missing my NY 914 in VA Group: Members Posts: 1,338 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
THat is VERY unusual.
Perhaps one side of the diaphragm has cracked/broken causing the uneven pressure across the wear surface. I've never seen one like that, but it has to fail somehow. As for the 1/4" deeper hub on the disk. Not sure it should matter but I don't know which is original length, the current (and the other is 1/4" shorter) or the other way around. Get a measurement and we could tell you which is stock length. Eitherway, mostly likely you'd be fine as there is a fair amount of room in there. You just wouldn't want the splines ending and the disk being pushed backward by the input shaft toward the pressure plate. Interesting failure, thanks for sharing. |
Dr Evil |
May 29 2012, 03:00 PM
Any of those disks should be fine. The 4 spring disks are even thicker in the center. Strange failure, for sure.
Valy |
May 29 2012, 05:27 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
How is your flywheel?
Looks like the throwout bearing was pressing off center but I can't know who caused what first. Was the bearing properly installed? Anyway, I would double check the bearing as they are not build to sustain lateral forces and it may have some heay wear now. |
ottox914 |
Jun 4 2012, 08:46 AM
Hows THIS for customer service...
On Jun 4, 2012, at 9:37 AM, brett baltau wrote: The clutch had a broken diaphragm. Not sure of the cause of it braking. It has been fixed and sent back out to you already at no charge. Brett Kennedy Engineered Products 38822 17th st. east Palmdale, Ca. 93550 brett@kennedyeng.com Phone 661-272-1147 Fax 661-272-1575 They have earned a customer for life with me... |
ape914 |
Jun 4 2012, 11:57 AM
red locktite Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None |
Been a bit since the last time I did a clutch IN a car. I seem to recall hearing of doing one w/out taking the trans out. I'd rather not have to do that, as removing the exhaust, turbo bits, and trans adds a lot more work. Ant thoughts or hints/tips? Its just me in the garage today, so hopefully I can get this done for the weekend. i would be interested in seeing photos of the turbo bits on your car, what you got???? |
bembry |
Jun 4 2012, 04:32 PM
Senior Member Group: Members Posts: 529 Joined: 29-July 05 From: Bakersfield, CA Member No.: 4,499 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 26th November 2024 - 02:22 AM |
