engine ID questions., see photos |
spare time toys |
Oct 15 2004, 06:01 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
Where on this are the ID codes at I cant find them (IMG:style_emoticons/default/confused24.gif) its supposed to be a 1.7 the pink color is overspray it sat in the corner of the shop andI thought I covered this when I painted the car
Attached image(s) |
spare time toys |
Oct 15 2004, 06:03 PM
what is the threaded hole next to the intake for? Should I plug it for a non street eng?
Attached image(s) |
davep |
Oct 15 2004, 06:04 PM
914 Historian Group: Benefactors Posts: 5,225 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
For a 1.7 it should be on the angled rib towards the flywheel end. A 2.0 would be in front of the oil filler. A replacement block would have neither.
spare time toys |
are these the angle plug heads? The intake has four bolts holding it on.
Attached image(s) |
Mueller |
Oct 15 2004, 06:06 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
4 bolts= 1.7, 1.8 or Bus 2.0 heads
Bleyseng |
Oct 15 2004, 06:07 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
No, they point straight up so its a 1.7,1.8 or bus head.
Hmmm, they filled the head breathers with the bolts and added vent tubes on the valve covers. |
spare time toys |
Oct 15 2004, 07:33 PM
QUOTE(Bleyseng @ Oct 15 2004, 07:07 PM) they filled the head breathers with the bolts and added vent tubes on the valve covers. What ones are filled? The holes Im asking about are next to the intake ports and have threads in them. Is that the head breather you are talking about because it is not plugged? |
SirAndy |
Oct 15 2004, 08:38 PM
Resident German Group: Admin Posts: 41,957 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(spare time toys @ Oct 15 2004, 06:33 PM) Is that the head breather you are talking about because it is not plugged? yes, it looks redundant ... the head-breather and the vent on the valve cover serve the exact same purpose. you need only one of the two. the head-breather is usually preferred because you don't need to cut into your engine sheetmetal to use it ... (IMG:style_emoticons/default/wink.gif) Andy |
Mark Henry |
Oct 16 2004, 10:00 AM
Tell us the head # (under the rocker shaft) and I'll tell which heads you have.
spare time toys |
Oct 16 2004, 03:44 PM
QUOTE(Mark Henry @ Oct 16 2004, 11:00 AM) Tell us the head # (under the rocker shaft) and I'll tell which heads you have. It looks like 021.101.371J then there is a 1 in a circle. |
Aaron Cox |
Oct 16 2004, 03:48 PM
anyone else trippin on those funky intake manifolds? those are funky!!! (IMG:style_emoticons/default/laugh.gif)
they match the cage i guess (IMG:style_emoticons/default/lol2.gif) , jk Larry, its lookin good, what are the plans for the motor? remember - POEAF (pink overspray'd engines are faster) PS-what carbs are those? |
type47 |
Oct 16 2004, 06:37 PM
the little threaded holes are for the engine cooling sheet metal?
Aaron Cox |
Oct 16 2004, 06:41 PM
also, whats with the oil filler cap? ive never seen one with a breather port
Mark Henry |
Oct 17 2004, 05:27 AM
1.7 heads....
So it's most likely a 1.7, but you can bore 1.7 heads out to fit a 1.8 or 2.0L, so no 100% guaranty that it is a 1.7. |
Mark Henry |
Oct 17 2004, 05:58 AM
Yep…those manifold are funkadelic, what are the carb #’s and do the manifolds have any markings?
Can you give me the measurement (see pic) from top of the carb to the top of the valve cover?. Also I'd love to know whats up with that plate bolted to the VC side of the manifold. Attached image(s) |
skline |
Oct 17 2004, 06:16 AM
The carbs look like some old DCNF carbs I had awhile back. They had that same type of manifold. The small screw holes next to the manifold are for screws to hold the sheetmetal down. You do not need to put anything in there if you are not going to put the sheetmetal back on. I would not run one of these engines without the sheetmetal however, it wont live long without cooling. 1.7 heads I thought were the only ones with the vent tube, 1.8 heads didnt have them.
spare time toys |
Oct 17 2004, 08:12 AM
QUOTE(Mark Henry @ Oct 17 2004, 06:58 AM) what are the carb #’s and do the manifolds have any markings? Can you give me the measurement (see pic) from top of the carb to the top of the valve cover?. Also I'd love to know whats up with that plate bolted to the VC side of the manifold. Ok I went out and got what you wanted. The carbs are Solex mod. 40-p11-4 the measurement on the intake is 3.5 inches and the numbers cast into the intake is the VW in a circle then 021 12 0 with 709n under it. The plate holds the linkage on the forward side. |
Mark Henry |
Oct 17 2004, 07:16 PM
1.7 heads
021-101-371J 021-101-371Q 021-101-372 1.8 heads 021-101-371H 021-101-371S 2.0 bus 022-101-372G 2.0 vanagon 071-101-371A 071-101-371B 914 2.0 039-101-371A Some had vents, some didn't. Solex 40-p11 are real old school...they were never a great carb...ebay them and put the cash towards a new set of webers. OR gut them and use them as TB's for a FI setup. |
Aaron Cox |
Oct 17 2004, 07:33 PM
dude! i believe those solexes and manifolds are worth some money to vintage racers!
werent these the RARE VW 914 manifolds for the euro 1.8? these were sought after by racers as a 'factory' way of putting carbs on a Production class race car please correct me if im wrong |
Mark Henry |
Oct 17 2004, 07:41 PM
Maybe to a vintage buff...I'd rather have new (newer) Weber carbs. I've only ever tuned them once (on a T1 bug) and they were a total PITA.
Lo-Fi Version | Time is now: 4th January 2025 - 09:21 PM |
