shift rod head, same part? |
bugsy0 |
Jun 12 2012, 12:47 AM
Member Group: Members Posts: 191 Joined: 26-July 06 Member No.: 6,508 Region Association: None |
Are these two parts interchangeable?
Part No. 28 in this diagram: and part No. 24 in this diagram: It's easy to say "no" as they are different part numbers. However they are very close. Here's a picture of part 24 (930-424-241-00): I need part 28 (914-424-241-02). If anybody could verify the distance from the center of the screw to the flush end I would very much appreciate it. It's about 1 7/8" on part 24. Thanks |
euro911 |
Jun 12 2012, 02:10 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
That's an interesting question (IMG:style_emoticons/default/idea.gif)
What's the OD of the front shit rod where part (24) attaches? ... same as the OD on the rear shift rod? (I don't have either handy at the moment). I think part (29) looks a littler 'beefier' (IMG:style_emoticons/default/confused24.gif) |
JWest |
Jun 12 2012, 06:08 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
No, the side-shift rear cup is taller than the shifter cup.
ChrisFoley |
Jun 12 2012, 06:49 AM
I am Tangerine Racing Group: Members Posts: 7,968 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
While they seem to be interchangeable, and both attach to the rod identically, using the tailshift piece at the console of a sideshift trans doesn't work out too well.
The ball cup bushing hangs out of the end, jams, and breaks quickly. Somewhere around here I have a tailshift piece which I extended using a 12pt. socket at the race track, after discovering (the hard way) that I had used the wrong piece when assembling the car. Fortunately I had a spare bushing in my parts box as well. (IMG:style_emoticons/default/unsure.gif) |
bugsy0 |
Jun 12 2012, 08:25 AM
While they seem to be interchangeable, and both attach to the rod identically, using the tailshift piece at the console of a sideshift trans doesn't work out too well. The ball cup bushing hangs out of the end, jams, and breaks quickly. Somewhere around here I have a tailshift piece which I extended using a 12pt. socket at the race track, after discovering (the hard way) that I had used the wrong piece when assembling the car. Fortunately I had a spare bushing in my parts box as well. (IMG:style_emoticons/default/unsure.gif) Another use for old sockets (IMG:style_emoticons/default/smile.gif) i imagine it worked out fine. Probably got you through the day. I had a hunch the one part was longer. Other than length, the tail shift piece does look like it would work. It only needs another 1/4" so it's easy to confuse the two. Thanks for clarifying, guys. |
TheCabinetmaker |
Jun 12 2012, 08:27 AM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I have a few if you need one.
1slow914 |
Jun 12 2012, 01:49 PM
Newbie Group: Members Posts: 1 Joined: 12-June 12 From: jaclsonville FL Member No.: 14,557 Region Association: None |
@vsg914 = pm me about that shift rod head please!
@bugsy0 =im in the same situation, did a side shift conversion and all parts were there minus shift-rod head (part 28) since i have (part 24, diagram 2) from swap, tried it to no avail. used a 11/16 socket and tried that, but ball cup bushing kept slipping out. called local Porsche dealer (Brumos) and i was told that part is discontinued. and the woes continue... (IMG:style_emoticons/default/huh.gif) |
bugsy0 |
Jun 13 2012, 12:55 AM
I think these parts are very easily confused as they only differ by about 1/4" in length and both work in either application (for a desperate, late night mechanic in denial).
bugsy0 |
Jun 13 2012, 12:57 AM
...or if you're at the track and need it to work Now
Dave_Darling |
Jun 13 2012, 09:19 AM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I remember Gint's car (the Six) going on a drive with the Roadglue folks. The gear shift lever suddenly wouldn't shift. Mueller was riding with Alex, who was the car's owner at the time. The coupler under the lever was the wrong type, so Mueller kludged up a fix to get the car home.
So yeah, it doesn't work that well the other way either. --DD |
Lo-Fi Version | Time is now: 26th December 2024 - 05:44 PM |
