Jumpy tach |
Jumpy tach |
mittelmotor |
Jun 13 2012, 03:03 PM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
My tachometer needle tends to jump around a lot, rather than swinging in a nice smooth arc. Any suggested fix? If others have experience here, I'd love to hear how you've fixed it.
Thanks! |
brant |
Jun 13 2012, 03:04 PM
914 Wizard Group: Members Posts: 11,824 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
do you still have points.
often its an ignition or points signal problem |
Black22 |
Jun 13 2012, 03:10 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
I've have the same problem. Seems to be very common on our cars. I have a point-less system and it still bounces. I'll be watching his thread.
SirAndy |
Jun 13 2012, 03:15 PM
Resident German Group: Admin Posts: 41,944 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Several years ago, i bought a (brand new) relay board for unrelated reasons and one of the (many) things it fixed was my jumpy tach.
My guess is that on many cars the solder connections on the relay board are getting tired after 40+ years of abuse. (IMG:style_emoticons/default/popcorn[1].gif) |
mittelmotor |
Jun 13 2012, 03:25 PM
Thanks! Car still has points. Now I have some areas to start the troubleshooting process.
brant |
Jun 13 2012, 03:42 PM
Thanks! Car still has points. Now I have some areas to start the troubleshooting process. on cars I have run points on.... I always notice an improvement when I reset dwell, clean up the points, and check the timing... I noticed on cars with points that the tach would be bouncy and it would get slowly worse without me noticing. worth checking your dwell and maybe replacing any worn points. cheap enough to try brant |
Bartlett 914 |
Jun 13 2012, 04:03 PM
Advanced Member Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
You will find threads about changing capacitors in the tach. This may be a solution. I was under the impression that some dampening of the needle was done and may no longer be working correctly. Think grease or some such component. My tach was jumpy and nothing helped.
914Bryan |
Jun 13 2012, 07:03 PM
Member Group: Members Posts: 190 Joined: 6-June 11 From: Orange County Member No.: 13,162 Region Association: Southern California |
There were a lot of ideas here, I just learned to live with it and will fix another day. Check out this thread for possibilities:
http://www.914world.com/bbs2/index.php?sho...=148422&hl= Good luck |
Series9 |
Jun 14 2012, 09:13 AM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Thanks! Car still has points. Now I have some areas to start the troubleshooting process. on cars I have run points on.... I always notice an improvement when I reset dwell, clean up the points, and check the timing... I noticed on cars with points that the tach would be bouncy and it would get slowly worse without me noticing. worth checking your dwell and maybe replacing any worn points. cheap enough to try brant (IMG:style_emoticons/default/agree.gif) |
sean_v8_914 |
Jun 14 2012, 09:19 AM
always check teh cheap stuff first but...NH speedo told me that the damping fluid goes away after 40 years. they rebuilt my tach and it tracks solid now
but check teh easy cheap solutions first |
Valy |
Jun 14 2012, 12:44 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I had the same problem in the past.
I took a plot of the points voltage with my scope. The blue line is the actual voltage on the points and the red one is what you would like it to look like. The biggest problem is that the negative spikes near the pulse middle cause the tach to believe the engine is spinning faster than it realy does. Some spikes are dumped by the tach filtering circuit but some are too big for it to handle so you see the tach jumping up. |
larss |
Jun 14 2012, 12:55 PM
Member Group: Members Posts: 431 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
My tach got cured from jumping after fixing the earth wire inside the dizzy (that connects the plate to the body), the connection had come lose and I re soldered it.
Lars S |
hedgehog |
Jun 14 2012, 01:25 PM
Member Group: Members Posts: 50 Joined: 6-June 06 From: Central Calif Member No.: 6,169 Region Association: Central California |
what i found when i had that problem was a loose coil wire....
Lo-Fi Version | Time is now: 26th December 2024 - 05:15 PM |
