Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
I am putting together doors for my newest project. I installed the new rubber window scraper seal. The rubber is nice and soft. The problem is the window goes up but down is a problem. The rubber sticks to the window and wants to pull in. I cleaned the window and this does not help. I am sure as the rubber ages, it will get harder and work properly. I am thinking I need to coat the rubber with something but I don't know what will work best. Anyone have this issue? Suggestions welcome
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
go to the drug store, wallgreens etc, buy some glycerin and dress the seal. REALLY clean the ext of the windows.
k |
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
just did the same thing to my brothers car! Im gonna try them when i get home.I never rolled the window up and down after install (IMG:style_emoticons/default/huh.gif)
(IMG:style_emoticons/default/smile.gif) |
Bartlett 914 |
Black22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest ![]() |
This happened to me as well. I used that spray detailing wax on the windows and the seal. It was a problem for the first couple of weeks, but will go away. Actually the cleaner the seals, the more they will grip. Your actually waiting for a fine layer of dust to collect on the seal.
I just hope your inside door handles work! |
SUNAB914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States ![]() |
Silicone spray in a can, make sure the channel isn't bent. Silicone spray is your best friend for all those seals.
rhodyguy |
they may streak bit initially but it will wipe off easily and the glycerin won't damage the paint.
k |
Bartlett 914 |
r_towle |
Do that yearly on all your rubber and you can keep it looking like new.
rich |
etcmss |
etcmss ![]() ![]() Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest ![]() |
done this several times and not had the problem. Where did you get the seals?
6freak |
go to the drug store, wallgreens etc, buy some glycerin and dress the seal. REALLY clean the ext of the windows. k Glycerin did the trick. Not messy as I thought it might be. Thanks Kevin. right on! go to know (IMG:style_emoticons/default/smile.gif) |
zonedoubt |
Canadian Member ![]() ![]() ![]() Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada ![]() |
I used baby powder (talcum).
McMark |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Funny
I have occasionally heard this is an issue. It really sounds like the rubber IS too clean. Glycerine sounds like the best answer. I'm installing a new set on the doors of my sons car in a day or two and I'll look specifically at this. Also aerospace 303 has a sacrificial coating that may help. I usually pre treat my seals. It may have been why I didn't have any issues on my car. |
Bartlett 914 |
Funny I have occasionally heard this is an issue. It really sounds like the rubber IS too clean. Glycerine sounds like the best answer. I'm installing a new set on the doors of my sons car in a day or two and I'll look specifically at this. Also aerospace 303 has a sacrificial coating that may help. I usually pre treat my seals. It may have been why I didn't have any issues on my car. And what do you pre treat your seals with? |
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
I used a piece of thin carboard between the seal and glass for about a week. Worked fine afterwards.
pt_700 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,095 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California ![]() ![]() |
how about some rain - x? when my wipers start to chatter across the windshield, a treatment really smooths things out.
reharvey |
Senior Member ![]() ![]() ![]() Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States ![]() |
I used a piece of thin carboard between the seal and glass for about a week. Worked fine afterwards. (IMG:style_emoticons/default/agree.gif) |
Mikey914 |
I use Aerospace 303 protectant. It has a sacrificial coating that helps to protect the rubber. I suspect it also lubricates it too.
Mark |
solex |
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States ![]() |
I snapped my window scrapers in using a plastic trim tool. This was much easier then sliding them in the channel
Lo-Fi Version | Time is now: 26th June 2024 - 03:26 AM |
