Oil temp sender and dry sump |
yeahmag |
Jun 20 2012, 10:37 AM
Advanced Member Group: Members Posts: 2,435 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Where would be the appropriate place to take oil temps from when converting to dry sump. My thoughts were either at the tank or utilizing one of the ports in my thermostat:
http://www.summitracing.com/parts/EAR-501ERL/ Opinions? -Aaron |
SLITS |
Jun 20 2012, 10:40 AM
Ideally somewhere in the engine oil galleries.
I don't think the scavenge line is full enough to properly trigger a sender, but then again, I don't really know. In any case, you want to know what the temp of the oil is in the engine. |
yeahmag |
Jun 20 2012, 10:41 AM
I was thinking in the return to the engine might be a good spot too.
ChrisFoley |
Jun 20 2012, 11:20 AM
I am Tangerine Racing Group: Members Posts: 7,958 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I put mine in the oil tank.
McMark |
Jun 20 2012, 11:31 AM
In the tank will essentially tell you the temp of the oil going into the engine. I would bet that there is very little variation throughout the whole system.
mrbubblehead |
Jun 20 2012, 02:01 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i am using the same t-stat. my temp is taken right after the cooler, right before the oil goes to the mains.
pcar916 |
Jun 20 2012, 04:21 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
I'd use the normal one in the engine, then another anywhere after the cooler. I like to know the efficiency of the cooling system in addition to the BTU specs of the cooler. Stuff like running the return line over the exhaust pipe makes a difference on the sixes.
An infrared thermometer on the inlet, then on the exit of the cooler is a great way to measure the performance of the cooler alone. If you want to go easy I'd think about a surface-mount sensor and a digital gauge... no drilling and tapping, you can glue those puppies all over the place, and sample any one you wish with a single gauge and a little switch fabrication. Life is good with instrumentation. Good luck |
yeahmag |
Jun 20 2012, 04:30 PM
So are using any of the 1/8" NPT ports to monitor anything? Mines going to be on the scavenge side, so I doubt the are useful for anything for me...
i am using the same t-stat. my temp is taken right after the cooler, right before the oil goes to the mains. |
yeahmag |
Jun 20 2012, 04:32 PM
Not sure it would be covered with enough oil to make it accurate in a dry sumped moter. That would also be the temp of the oil leaving the engine and not the temp of the oil coming to the engine.
I'd use the normal one in the engine, then another anywhere after the cooler. |
mrbubblehead |
Jun 20 2012, 04:44 PM
So are using any of the 1/8" NPT ports to monitor anything? Mines going to be on the scavenge side, so I doubt the are useful for anything for me... i am using the same t-stat. my temp is taken right after the cooler, right before the oil goes to the mains. yes i am using all but one of them. i also had to add an aditional an fitting with an 1/8 port....(i wanted to monitor temps weather it was in bypass mode or not) oil pressure sender, oil pressure idiot light, and oil temp. i am using mine on the pressure side. |
yeahmag |
Jun 20 2012, 04:46 PM
I'd guess you are wet sump then. Is that correct?
mrbubblehead |
Jun 20 2012, 04:48 PM
yeahmag |
Jun 20 2012, 04:49 PM
Oh! We need to talk then!
QUOTE no...im dry sump. |
mrbubblehead |
Jun 20 2012, 04:53 PM
Lo-Fi Version | Time is now: 28th September 2024 - 07:19 PM |
