73 914 2.0 FI Fuel Pump Blister Alternatives Moving Fuel Pump |
kbrunk1 |
Jul 28 2012, 08:22 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Moving fuel pump on 73 2.0 FI to front under the tank.
I do not have a fuel blister ? Can I just use clamps - ?? rubber dampners?? What can I use to minimize the vibration? noise? and make it work? Thanks for any alternative designs or ideas! |
SLITS |
Jul 29 2012, 08:22 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Mount it underneath near the rack. Local junk yard should have fuel pump holders with rubber isolators. Have to remove fuel tank for inner nuts on isolators.
Screw hose clamp, mounted with sheet metal screw to body (firewall above rack), wrap layer of rubber around pump or maybe two hose clamps ... looks Mickey Mouse (if anyone crawls under car and removes rack splash plate) but works. Run fuel hoses w/ filter thru big inspection hole. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:03 AM |
