Bilsteins- which should I use?, The yellows have a shorter piston length |
914_teener |
Aug 8 2012, 11:44 PM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
So a question for the collective and gathering parts for the wintertime project:
Got a couple pairs of Billy's from Bruce S for my front end that I am planning on swapping out. Plan was to rebuild the sets and then swap out the a-arms with new ball joints bushings ect. Currently the car is lowered in the front about 1 -1/2 inches lower than stock spec with the current a-arms not quite parallel to the ground. I run a bump steer kit as well...(although I still get some bump steer). I noticed that the yellow inserts have shorter piston length but have the same part number. Question: Which ones should I run on the car for the current set up and does anybody have any experience on the valving set up for the Billy's? I am told they will rebuild them for $75 each. Car will be street driven mostly. I am concerned about bottoming out the longer length pistons and busting the valving with the car lowered in the front. Thanks |
ChrisFoley |
Aug 9 2012, 07:14 AM
I am Tangerine Racing Group: Members Posts: 7,969 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The way to avoid damaging the valves is to install plastic packing washers which prevent the pistons from bottoming.
kerensky |
Aug 9 2012, 09:11 PM
Senior Member Group: Members Posts: 531 Joined: 1-February 06 From: Norman, OK Member No.: 5,508 Region Association: Southwest Region |
All other things being equal, I'd use the shorter inserts on a lowered car. Not that there's a big difference between those two.
Lo-Fi Version | Time is now: 4th January 2025 - 09:50 PM |
