Joseph Mills |
on a Sonoma diet now... ![]() ![]() ![]() Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 ![]() |
not quite "correct". (IMG:style_emoticons/default/biggrin.gif)
Only happens when the engine is cold. I'm pretty sure it's the alternator. Anyone else have an alternator that is occasionally noisey? I assume it's a bearing. Do I just let it go? Or will it screwup the unit even further? Do I just have to replace it with a rebuilt unit? (IMG:style_emoticons/default/unsure.gif) |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Your alternator bearing is going out. PITA to replace.
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
(IMG:style_emoticons/default/agree.gif) It may be a bearing. The alternator is a likely source. (IMG:style_emoticons/default/wink.gif)
TheCabinetmaker |
Joseph, do I need to come down with my sthetiscope? Do I hear a road trip coming up? (IMG:style_emoticons/default/smilie_pokal.gif) It's been a whole week since the ramble! (IMG:style_emoticons/default/biggrin.gif)
Joseph Mills |
QUOTE(vsg914 @ Oct 25 2004, 07:08 PM) Joseph, do I need to come down with my sthetiscope? Do I hear a road trip coming up? (IMG:style_emoticons/default/smilie_pokal.gif) It's been a whole week since the ramble! (IMG:style_emoticons/default/biggrin.gif) Ha! Still got the Tour Monkey on your back don'cha! (IMG:style_emoticons/default/biggrin.gif) Me too. I did a "cruise" with the VW folks last weekend to the Rt. 66 museum. Friendly folks that luvs their volks! (IMG:style_emoticons/default/wub.gif) So do I replace just the bearing, or the entire alternator? (IMG:style_emoticons/default/wacko.gif) And cost will be....??? |
TheCabinetmaker |
Replace the alternator. I have one waiting to picked up from my rebuilder. $85.00. He builds them guud!
I took another tour as well this weekend. Had a very nice day with the bartender from the WaterZ edge!!!! (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/smilie_pokal.gif) How about a Talimena drive tour in the next few weeks????????? |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
most altenator repair shops can doa bearig and test the entire unit for less than that. I had my 928 alt rebuilt with new volt regulator for 75 bucks.
Our volt regulators are not even on the alt. I think the remove replace effort is fairly easy. and can be done while engine is still in the car. Loosen the fan tension binder bolt pull the belt. 2 bolts and it is out. one on top that holds bracket to fan housing and the pivot bolt at the bottom. pull the plug at the circuit board and bam on the ground. Oh don't forget to disconnect the battery. |
Joseph Mills |
QUOTE(vsg914 @ Oct 25 2004, 07:26 PM) I took another tour as well this weekend. Had a very nice day with the bartender from the WaterZ edge!!!! :rolleyes: :wub: ;) :trophy: How about a Talimena drive tour in the next few weeks????????? Did you go wide and deep in the curves? (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) Talimena Drive? Mongo likes very much. (IMG:style_emoticons/default/monkeydance.gif) I think I'll wait on the alternator until it keeps making noise even after it is warm. (IMG:style_emoticons/default/biggrin.gif) |
TheCabinetmaker |
Most alt shops replace only the parts necessary to get the unit to minimum output specs. Paul is a bosch authorized repair point and builds them to better than factory specs. He also builds high torque starters.
Curvie Roadlover |
Two trunks are better than one! ![]() ![]() ![]() ![]() Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 ![]() |
When I heard a whirring coming from my engine compartment, a stethescope diagnosed my noise as coming from the distributor. A couple of drops of oil down the shaft stopped it. (IMG:style_emoticons/default/confused24.gif)
Joseph Mills |
Thanks Tom. I'll check that out tomorrow.
One can always hope. (IMG:style_emoticons/default/biggrin.gif) |
Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
Maybe the gerbils got a hold of some coke and are working overtime!
(IMG:style_emoticons/default/w00t.gif) |
Joe Ricard |
Although it could be something in the fan or rubbing it the wrong way. just throw a gerbil in the cooling fan It's like a turbo charger.
Joseph Mills |
QUOTE(Qarl @ Oct 25 2004, 08:49 PM) Maybe the gerbils got a hold of some coke and are working overtime! (IMG:style_emoticons/default/w00t.gif) Maybe gerbils do coke in Florida Quarl, but around here they would most likely get into some Moonshine. (IMG:style_emoticons/default/biggrin.gif) Can someone, with experience, please describe the sound I should listen for from drunk gerbils in a type 4 cooling fan. (IMG:style_emoticons/default/rolleyes.gif) I gotta' get to the bottom of this. |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,339 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Well, if your Gerbils are doing coke, they will have a tendecy to fall off leaving work for the others, so you might notice a loss in power from time to time. If they are drunk, each time you pull up to a stop sign listen closely as you might hear a "burp" once in a while.
That is about the only way I know to tell the difference. Either way, get them into re-hab asap so they continue to give you many trouble free miles. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 09:04 AM |
