914/6 front rotors, Zimmerman |
303racing |
Sep 26 2012, 07:38 PM
Newbie Group: Members Posts: 17 Joined: 11-July 12 From: California Member No.: 14,654 Region Association: Southern California |
Shopping front rortors for my 914/6 and looking at the Zimmerman drilled. any feed back, good or bad.
Thank, Tim |
brp986s |
Sep 26 2012, 08:39 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
I've had a set for a few thou miles. No problems. But mine is a street car, so they've never been smokin' hot. Somehow I ended up with another set that fit carrera that I can't use. If you're running "A" calipers maybe you'd be interested. Verify fitment. They're new, but one got wet and has superficial rust. Half new $.
303racing |
Sep 26 2012, 09:02 PM
I've had a set for a few thou miles. No problems. But mine is a street car, so they've never been smokin' hot. Somehow I ended up with another set that fit carrera that I can't use. If you're running "A" calipers maybe you'd be interested. Verify fitment. They're new, but one got wet and has superficial rust. Half new $. PM SENT |
Eric_Shea |
Sep 26 2012, 09:42 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Carrera rotors are 24mm wide and the 914-6, 911 up to 1984 are 20mm wide. No workie on a -6.
I think drilled is fine. If you do serious road racing expect to see some cracks develop. Anything under that and you should be good. |
carr914 |
Sep 26 2012, 09:57 PM
Racer from Birth Group: Members Posts: 121,083 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I don't like Drilled Rotors. I've had the Zimmerman Ventilated - Good
Lo-Fi Version | Time is now: 27th September 2024 - 10:25 AM |
