yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
I'm running the oil lines for my dry sump and am going to have some square-ish openings to feed the lines through. Does anyone have a recommendation on what to use to protect the hose and the body? I'm envisioning a U shaped roll of material that would be close to that of a rubber grommet in feel.
-Aaron |
gothspeed |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None ![]() |
I have successfully used this door edge guard for irregular holes:
http://www.brandsport.com/prtk-39-401-05.html They sell it at Autozone too. |
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
McMaster Carr has an assortment of materials and shapes.
http://www.mcmaster.com/#flexible-strip-grommets/=jh6gfn |
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
Two more.
http://www.trimco.info/edge-trim.html and http://www.vintagecarparts.co.uk/categorie...seals-edge-trim The last time I got some I got it either from Summit, Pegasus or Racer Wholesale Parts... can't remember which. Good hunting. |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
-Aaron [/quote] I used fuel line.....slit down one side & work it into position. Add some 3M super weatherstrip adhesive if you feel like you need it, but my experience is that it stays in place excellently if cut to the right length to wedge into the opening. Yeah, yeah, I'm a redneck CSOB, but it works! |
mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
[quote name='wndsrfr' date='Sep 27 2012, 05:48 PM' post='1745241']
I'm envisioning a U shaped roll of material that would be close to that of a rubber grommet in feel. -Aaron [/quote] I used fuel line.....slit down one side & work it into position. Add some 3M super weatherstrip adhesive if you feel like you need it, but my experience is that it stays in place excellently if cut to the right length to wedge into the opening. Yeah, yeah, I'm a redneck CSOB, but it works! [/quote] (IMG:style_emoticons/default/agree.gif) thats exactly what i did.... |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) Cheap and easy.
mrbubblehead |
heres how my oil line penetration came out...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1348868875.1.jpg) |
JoeSharp |
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States ![]() |
Yep!!
Lo-Fi Version | Time is now: 26th June 2024 - 02:46 AM |
