TJB/914 |
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,341 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest ![]() ![]() |
These tool's were given to me (free) by a business client. He said his father used to own some kind of Porsche (didn't know what model).
Any one know if they are valuable or used on a 914? Tom Picture attached. Attached thumbnail(s) ![]() |
Rusty |
Wanted: Engine case GA003709 ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,943 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch ![]() ![]() ![]() |
I believe those are 914/6 tools... used for oil line removal, adjusting the fan belt, etc.
If you have no need for them... I might be interested. |
GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
The small open end one with the three hex holes is for adjusting folding closet doors. I have several in different sizes....
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
The threaded eye bolt is a tow hook.. screws into a threaded hole that's behind the plug on the left side of the rear bumper. (on early cars, not sure if late plastic bumpered cars have it or not)
GTeener |
914 Girl ![]() ![]() ![]() ![]() Group: Members Posts: 2,348 Joined: 25-June 04 From: SillyCon Valley Member No.: 2,249 Region Association: Northern California ![]() |
(IMG:style_emoticons/default/huh.gif) Loosening lug nuts, tow hoop (my BMW has one of those loops), tire keys (looks like what I use on my bicycle tires only bigger and steel (IMG:style_emoticons/default/wink.gif) ) and wrenches to loosen bolts
sanman |
Leaving California ![]() ![]() Group: Members Posts: 341 Joined: 17-June 04 From: Houston, TX Member No.: 2,219 Region Association: None ![]() |
GTeener Im impressed
AndrewBlyholder |
Member ![]() ![]() Group: Members Posts: 112 Joined: 20-September 04 From: Richmond, CA Member No.: 2,791 ![]() |
Rod and cylinders on the left are for tire lug nuts. You the put the round bar through the holes in the cylinder to create a handle, although the ones I've seen in the past have a longer bar for more leverage.
Andrew |
GTeener |
QUOTE(sanman @ Oct 29 2004, 12:32 PM) GTeener Im impressed Thanks! Doesn't mean I can fix my own 914 (IMG:style_emoticons/default/lol2.gif) but I can identify parts (IMG:style_emoticons/default/biggrin.gif) |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,712 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(AndrewBlyholder @ Oct 29 2004, 01:36 PM) Rod and cylinders on the left are for tire lug nuts. actually, those are for Spark-Plug removal ... (IMG:style_emoticons/default/cool.gif) Andy |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Arent the rod and cylinders actually for spark plugs. Used to have one just like them for the lawnmower.
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,163 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) With Lawrence.
Some of them came with the 914/4, but only a few of them. This is from a 914/6. Attached image(s) ![]() |
TJB/914 |
GTeener is probably trying to set me up for a cheap sale.
I forgot to say they were made in Western Germany by Heyco (Chrom-Vanadium). The two that look like shoe horns is tough one to figure out?? Lawrence contact me & let me know what you want. Tom |
davep |
The "shoe horns" look like tire irons used to pry a tire from the rim. You need at least two.
GWN7 |
The tire wrenchs look a little small. The only one's I have used were a lot longer. About 2' long. You need leverage to get the tire bead over the rim. The one's shown look more like for bycycle tires.
GTeener |
QUOTE(Thomas J Bliznik @ Oct 29 2004, 12:44 PM) GTeener is probably trying to set me up for a cheap sale. I forgot to say they were made in Western Germany by Heyco (Chrom-Vanadium). The two that look like shoe horns is tough one to figure out?? Lawrence contact me & let me know what you want. Tom I'm just playing the guessing game. I'm not a mechanic. I pay attention to the guys that are (IMG:style_emoticons/default/biggrin.gif) |
scruz914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 26-February 04 From: Santa Cruz, CA Member No.: 1,724 ![]() |
Those two "shoe horns" are exactly the size for bike tires.
This one is for tightening and removing older style bicycle cranks. Attached image(s) ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,002 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Doesn't the Six crank pulley (or fan pulley) use a tool like that when you want to replace the belt?
The smaller tubular one may also be useable for removing the CHT sensor in an injected four-banger. If the interior of the hex is 13mm, at least. --DD |
HarveyH |
Member ![]() ![]() Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 ![]() |
Isn't this the tool for rebuilding Delta single lever faucets? (IMG:style_emoticons/default/blink.gif)
Harvey Attached image(s) ![]() |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Dental tools for Howard and Scott!
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
QUOTE(SLITS @ Oct 29 2004, 02:59 PM) Dental tools for Howard and Scott! Ha Ha Ha, you a funny man Slits, now, how much for the little girls??? |
Lo-Fi Version | Time is now: 1st July 2024 - 06:22 AM |
