Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I adjusted it by earball. Really sounds good and revs up quick and smooth.
I want to get it right, though. What's the drill? KT |
DonTraver |
Senior Member ![]() ![]() ![]() Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 ![]() |
The spec is 35 degrees at 6000 rpm, I set mine at about 37 or 38, less popping from the carbs, runs great. Did a mileage check on the trip to the Riverside BBQ, getting 25.5 mpg at 80, whoo hoo.
These specs are for a stock 2.0 L six. If yours is anything else, double check your manual first. Take care, Don |
DonTraver |
Oh yeah, the flywheel is marked for timing and valve adjustment. I barred the engine over using a wrench on the crankshaft bolt below the fan shroud, look thru the small oblong hole behind the breather. I cleaned the marks using one of those toothbrush wire brushes, then highlighted the marks with white paint. Real easy to see now.
Good Luck, Don |
Trekkor |
Thanks, Don.
The motor is sitting on a pallet right now with a bus trans bell housing bolted on. I can start and run it. Can I set the timing off the front pulley? KT |
DonTraver |
Yes, The marks are just a lot smaller, might need to use one of those pot scubbers to clean off the pulley. 911's always use the front pulley.
Later, Don |
Lo-Fi Version | Time is now: 26th June 2024 - 02:29 AM |
