Gear Linkages - How do They Work? |
kbrunk1 |
Oct 22 2012, 08:37 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Reverse 1st 2nd 3rd work great.
Problem is not going into 4th and 5th How does the linkage work? Is it where it extends on each gear? Is there a way to check the linkage? Can you lift out the gear shift linkages and visually or test them? Should I look at the part on the transmission and see or test anything? Thanks |
GeorgeRud |
Oct 22 2012, 08:44 PM
There are a lot of adjustments in the linkage, and you may have some things misaligned. Did it go into 4th and 5th before, what changed? Was any work done the linkage? Are the bushings in good shape?
If in doubt, you can disconnect the linkage and check whether you can engage all the gears at the gearbox, then work your way back. |
Dr Evil |
Oct 22 2012, 08:47 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Sounds like a linkage issue. Do as discussed and get back to us.
balljoint |
Oct 23 2012, 12:31 PM
914 Wizard Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
Reverse 1st 2nd 3rd work great. Problem is not going into 4th and 5th How does the linkage work? Is it where it extends on each gear? Is there a way to check the linkage? Can you lift out the gear shift linkages and visually or test them? Should I look at the part on the transmission and see or test anything? Thanks This is too many questions to process. You should make each one a separate thread. (IMG:style_emoticons/default/smile.gif) |
76-914 |
Oct 23 2012, 12:41 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Ignore him. One of the Hall Monitors will be along shortly. Look at the u-joint bushings next to the firewall while your checking the set screws
walterolin |
Oct 23 2012, 01:05 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Couple of articles to start with:
http://www.pelicanparts.com/techarticles/9...ift_improve.htm and http://www.pelicanparts.com/techarticles/9...ift_improve.htm |
walterolin |
Oct 23 2012, 01:10 PM
Rotary'14 |
Oct 23 2012, 02:08 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Before you start tearing things apart,, it might be a simple fix. You should check to make sure all your bushings are in good shape,, on the shift rod, at the shift console of the trans, and beneath the shifter. I would also make sure the cone screws are tight. there is one at the firewall side and one at the shift console on the transmission. If one of your cone screws back out a bit it will make the shifting sloppy/or impossible to get all gears.
-Robert |
Lo-Fi Version | Time is now: 27th September 2024 - 10:36 AM |
