Another Dr. Evil transmission build. This one has some fancy bits |
Dr Evil |
Nov 16 2012, 10:06 PM
Here is a build I started tonight. It is going to be pretty special with an LSD and some billet bits. Even though I am not for billet intermediate plates, I still like the look and this customer had been amassing parts for a long time before he heard my thoughts on them. No biggie. They take good pics (IMG:style_emoticons/default/smile.gif)
What you see here is a 930 pinion bearing, the rare and NLA steel caged input bearing, and a billet plate. Attached image(s) |
Ductech |
Nov 16 2012, 10:16 PM
Member Group: Members Posts: 356 Joined: 16-July 10 From: AridZona Member No.: 11,949 Region Association: Southwest Region |
Pretty wicked lookin stuff thar Dr...
bigkensteele |
Nov 16 2012, 11:02 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Here is a build I started tonight. It is going to be pretty special with an LSD and some billet bits. Even though I am not for billet intermediate plates, I still like the look and this customer had been amassing parts for a long time before he heard my thoughts on them. No biggie. They take good pics (IMG:style_emoticons/default/smile.gif) What you see here is a 930 pinion bearing, the rare and NLA steel caged input bearing, and a billet plate. There is no beer, beef jerky, or flatulence haze in the picture. How do we know that this is your workshop and not some stock photo? (IMG:style_emoticons/default/poke.gif) |
sixaddict |
Nov 17 2012, 03:23 AM
Senior Member Group: Members Posts: 814 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Evil:
I have repeatedly trashed first year in apparent 4th to 3rd missed shift ...Have a rennshift and still did it ....Any suggestions other than tightening loose nut behind the wheel TOT |
Dr Evil |
Nov 17 2012, 07:58 AM
With a rennshifter you need to have your adjustments and shift linkage in perfect shape or you will start to erode your gear box. You should not be hitting 1st with a rennshifter, that is what it is expressly set up to prevent with its springs.
sixnotfour |
Nov 17 2012, 11:17 AM
914 Wizard Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
What kind of LSD ??
Cap'n Krusty |
Nov 17 2012, 11:28 AM
Here is a build I started tonight. It is going to be pretty special with an LSD and some billet bits. Even though I am not for billet intermediate plates, I still like the look and this customer had been amassing parts for a long time before he heard my thoughts on them. No biggie. They take good pics (IMG:style_emoticons/default/smile.gif) What you see here is a 930 pinion bearing, the rare and NLA steel caged input bearing, and a billet plate. The steel caged input shaft may be rare, and it may be NLA, but it was a lower cost replacement/substitute for the brass caged bearing when it appeared on the aftermarket. In fact, the brass one kinda disappeared from the market for a bit back in the late '70s/early '80s. It was never OE, IIRC, and never preferred. The Cap'n |
Dr Evil |
Nov 17 2012, 11:36 AM
Here is a build I started tonight. It is going to be pretty special with an LSD and some billet bits. Even though I am not for billet intermediate plates, I still like the look and this customer had been amassing parts for a long time before he heard my thoughts on them. No biggie. They take good pics (IMG:style_emoticons/default/smile.gif) What you see here is a 930 pinion bearing, the rare and NLA steel caged input bearing, and a billet plate. The steel caged input shaft may be rare, and it may be NLA, but it was a lower cost replacement/substitute for the brass caged bearing when it appeared on the aftermarket. In fact, the brass one kinda disappeared from the market for a bit back in the late '70s/early '80s. It was never OE, IIRC, and never preferred. The Cap'n The steel caged bearings were available up to about 5 years ago at some venders. It is a far superior design and does not break as easy as the brass caged nonsense. I have yet to see one fail. |
sixnotfour |
Nov 17 2012, 11:43 AM
brass-ebay-Carquip pinion bearing---- not input----
http://www.ebay.com/itm/Porsche-901-904-90...2946#vi-content |
Dave_Darling |
Nov 17 2012, 11:47 AM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
My mechanic had a number of unkind things to say about the brass-caged ones when we did the rebuild. He preferred the steel-caged bearings as well; probably because they were one unit and didn't fall apart as you were trying to install them. (At least, that's the impression that I got from what he was saying.)
--DD |
Dr Evil |
Nov 17 2012, 12:45 PM
brass-ebay-Carquip pinion bearing---- not input---- http://www.ebay.com/itm/Porsche-901-904-90...2946#vi-content Wrong bearing. |
Dr Evil |
Nov 17 2012, 12:46 PM
My mechanic had a number of unkind things to say about the brass-caged ones when we did the rebuild. He preferred the steel-caged bearings as well; probably because they were one unit and didn't fall apart as you were trying to install them. (At least, that's the impression that I got from what he was saying.) --DD The cages and balls can fall out, but the balls are captive in the cage. The main thing is that the steel doe snot shatter and the brass shatters very easy. I have seen more than once where a new one broke with minimal effort (not by me, luckily). That is a $200+ bearing that does this. |
sixnotfour |
Nov 17 2012, 12:49 PM
brass-ebay-Carquip pinion bearing---- not input---- http://www.ebay.com/itm/Porsche-901-904-90...2946#vi-content Wrong bearing. I know=== what LSD? |
Dr Evil |
Nov 17 2012, 12:50 PM
brass-ebay-Carquip pinion bearing---- not input---- http://www.ebay.com/itm/Porsche-901-904-90...2946#vi-content Wrong bearing. I know=== what LSD? Then why did you post it? |
sixnotfour |
Nov 17 2012, 02:40 PM
trigger finger remembered a repo bearing , they supply , ya wrong one ,but i left it and , put not input..maybe they could do a repo of the other. (IMG:style_emoticons/default/slap.gif)
does that splain it (IMG:style_emoticons/default/smile.gif) |
Qarl |
Nov 17 2012, 08:27 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I bet it's a Guard Torsen Differential going in there!
(IMG:style_emoticons/default/piratenanner.gif) |
iamchappy |
Nov 17 2012, 08:34 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Qarl cheated, he knows all the answers, because it's his.....
Cap'n Krusty |
Nov 17 2012, 09:13 PM
Qarl |
Nov 17 2012, 09:23 PM
Avoid the brown acid!
Dr Evil |
Nov 17 2012, 11:36 PM
Dang, well Qarl knows because it IS his (IMG:style_emoticons/default/smile.gif)
I am honored to be building such a fine transmission (IMG:style_emoticons/default/thumb3d.gif) More pics as I do things. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:08 AM |
