LCOX |
Member ![]() ![]() Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None ![]() |
Can I use a 2.0 crank and rods with a 1.8 case. Thanx! L
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,479 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Yep.
That is the basis for making a 2056. I am using a 2.0 crank and rods on a 1.7 case. For the most part, a case is a case and they are interchangable. Some things are different, but not much. Zach |
Cap'n Krusty |
Can I use a 2.0 crank and rods with a 1.8 case. Thanx! L Yes. If you then use OE 94mm pistons and cylinders you have a 2 liter engine. If you use the 1.8 heads, you have what is effectively a VW bus engine (watch the C/R! with those heads!). If you use 96 mm pistons, the ones made for a 2 liter crank, you have a 2056 or something like that. You'll have to be careful about the deck height as the compression ratio goes up as the bore increases. The Cap'n |
0396 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California ![]() |
Leave it to the Cap to educate us young ones....thank you:)
Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,483 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
Cap,n, what is the max compression ratio that you would recommend for a 2056? Thanks
VaccaRabite |
If you don't mind others answering...
You need a lot more variables before you settle on your CR. Stock injection? Carbs? Modern eFI (like Megasquirt) What cam are you using? Iron cylinders? New heads? Rebuilt? When you have answers to those questions, you can make an informed decision on your CR. Zach |
Lo-Fi Version | Time is now: 1st July 2024 - 06:21 AM |
