chris914 |
Member ![]() ![]() Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California ![]() |
Hi,
Whats the trick to replacing the rollers for the rear trunk? |
Lou W |
"Here Kitty Kitty" my ass...... ![]() ![]() ![]() ![]() Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain ![]() |
Did you try the Classic Message Sections?
d7n7master |
Gary# ![]() ![]() ![]() Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 ![]() |
If I had to do it again - I wouldn't... (IMG:style_emoticons/default/ohmy.gif)
My plastic/stock roller on the drivers side broke one day when I opened the trunk. When it broke, it damn near hit me but missed. That should have been an "across the bow" warning - but no - not me. I bought the aluminum replacement rollers. WOW!!! Cool. I could see that I just needed to pry the bar down & push the new roller on. So I grabbed my BIG Craftsman screwdriver/prybar. Close but no cigar. Couldn't quite pry the bar down enough due to the angle req'd. So I made a tool out of some titanium tubing I pulled out of scrap at work. Cut it to a length that would give me the correct angle. Put the tool over the bar on one side, pushed like a s.o.b. & slid the roller on. WooHoo!!! Not so bad. Cool tool! But when I did the other side, the tool slipped off the end of the bar. At the time I was pushing with all I had... result? - blood - mine. The tool had hit my thumb so hard, the force split my thumb open. I came back the next day & installed that roller very carefully. Next time, if there is one, I'll buy the truck kit that eliminates the rollers. Do yourself a favor - check it out. (IMG:style_emoticons/default/boldblue.gif) |
DJsRepS |
Member ![]() ![]() Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 ![]() |
The spring is killer. Made my rollers spring rides on a ball bearing with fender washers as a guide and smaller washers to position bearing and alan lock ring to hold it on. Pic inc
Attached image(s) ![]() |
scotty914 |
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 ![]() |
heres a way to do it with out breaking a sweat or skin
http://forums.pelicanparts.com/showthread....p?threadid=3829 makes it real easy look for the post by retro 74 |
914GT |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region ![]() |
I hope it isn't 'verboten' to do this, but read this post on the PP board: http://forums.pelicanparts.com/showthread....unk+roller+tool
Scroll down toward the bottom. I made a simple tool out of 1/2" tubing, and somebody else had good luck with it to release the tension on the rod. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
QUOTE(DJsRepS @ Nov 7 2004, 11:14 AM) The spring is killer. Made my rollers spring rides on a ball bearing with fender washers as a guide and smaller washers to position bearing and alan lock ring to hold it on. Pic inc Any better pictures? All I see is a yellow and gray blob. If you're having trouble with close-ups, hold the camera farther back and use the zoom function. |
Rusty |
Wanted: Engine case GA003709 ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,942 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch ![]() ![]() ![]() |
The rollers are evil. (IMG:style_emoticons/default/mad.gif)
Get Craig's rear trunk shock kit. (IMG:style_emoticons/default/wub.gif) -Rusty (IMG:style_emoticons/default/smoke.gif) |
Rhodes71/914 |
Glacier ![]() ![]() ![]() Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 ![]() |
QUOTE(Lawrence @ Nov 7 2004, 01:00 PM) The rollers are evil. (IMG:style_emoticons/default/mad.gif) Get Craig's rear trunk shock kit. (IMG:style_emoticons/default/wub.gif) -Rusty (IMG:style_emoticons/default/smoke.gif) I currently have a bad roller on my trunk that still works but poorly. I was messing with the spring system to try and fix it...I GOT SCARED... forget that whole system. Quick phone call to Craig at camp914 and $40 and a couple days later I had some shocks for the rear trunk. I think its the way to go. |
DJsRepS |
better camera and pic
DJsRepS |
another pic
Lou W |
QUOTE Rhodes71/914 Posted on Nov 7 2004, 01:09 PM (IMG:style_emoticons/default/agree.gif) I'm converting both my front and back over too.-------------------------------------------------------------------------------- QUOTE (Lawrence @ Nov 7 2004, 01:00 PM) The rollers are evil. Get Craig's rear trunk shock kit. -Rusty I currently have a bad roller on my trunk that still works but poorly. I was messing with the spring system to try and fix it...I GOT SCARED... forget that whole system. Quick phone call to Craig at camp914 and $40 and a couple days later I had some shocks for the rear trunk. I think its the way to go. |
DJsRepS |
test port
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,103 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
raise the trunk. use a deep 8, 9,or 10mm(i forget) socket and extension. slip it over the spring end. it will push down easily so you can slip the roller on. if you are going to stay with springs, use the metal rollers. you need the correct fuel line clamps. (IMG:style_emoticons/default/ohmy.gif)
kevin |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
(IMG:style_emoticons/default/agree.gif) with Kevin. done it a few times. 10mm deep.
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Chris,
I have the trunk shock kit and find it to be a better invesment. The springs put a lot of tension on your trunk hinges and will ultimately help them to fail where as the shocks only put force ont he trunk when its open. You can come by and check out my install if you like. If you want help installing the rollers I can do that too. It was easy the first time I did it with a 10mm socket and extension. Mike |
Dr Evil |
DJsREPS,
You really should replace those hose clamps on you fuel lines for the correct type (smooth). The type you have eventually will cut into your hoses. HTH |
chris914 |
Thanks everyone for the input.
The car is for Autocross use only. I'm going to take the springs and rollers off all together. Get rid of that extra weight. I'll will but a stick in the truck if I need to hold it open. lol |
plas76targa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region ![]() |
Chris, and others who may contemplate this..
Instead of a deep socket, I used the spark plug tool out of my 9-elebin tool kit. the hex end fits nicely over the spring steel. Get a helper to push down on the spring while you swap the plastic for the new aluminum roller. Schweet and easy change-over. 'course I can understand your current approach.. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,547 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Take a 12" cresent wrench. Cut a notch in the loop on the back end until you have a C shaped opening instead of the loop. Hook it over the torsion bar, and pry down the torsion bar until you can change the roller.
Cheap, easy, and you already have it in your toolbox. |
Lo-Fi Version | Time is now: 20th June 2024 - 08:56 AM |
