jdlmodelt |
James D. Lane ![]() ![]() Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region ![]() |
What drives the tachometer in the 72 914?
r3dplanet |
Senior Member ![]() ![]() ![]() Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None ![]() |
mittelmotor |
Member ![]() ![]() Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None ![]() |
Elves. It's actually just a simple gear inside the transmission that rotates a cable. Old school. -m. What drives the tachometer in the 72 914? The speedometer is cable-driven, not the tach. Or maybe the earlier cars had a mechanical tach? |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
Elves. It's actually just a simple gear inside the transmission that rotates a cable. Old school. -m. What drives the tachometer in the 72 914? (IMG:style_emoticons/default/slap.gif) fail!! it's driven off the points side of the coil |
r3dplanet |
Oh right. My mistake. I was thinking of the odometer cable. Sorry, I changed to a new brand of crack.
jdlmodelt |
Elves. It's actually just a simple gear inside the transmission that rotates a cable. Old school. -m. What drives the tachometer in the 72 914? (IMG:style_emoticons/default/slap.gif) fail!! it's driven off the points side of the coil I have a wire there that I have not connected yet. So you are saying it connects to the negative side of the coil? That's the side I have the points connected to. It makes a very small spark when I touch it to the negative side of the coil. Back when I was trying to get the engine running, when I connected that wire it kept the engine from firing. So I've left it disconnected? |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Oh right. My mistake. I was thinking of the odometer cable. Sorry, I changed to a new brand of crack. Now that was funny... (IMG:style_emoticons/default/lol-2.gif) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I have a wire there that I have not connected yet. So you are saying it connects to the negative side of the coil? That's the side I have the points connected to. It makes a very small spark when I touch it to the negative side of the coil. Back when I was trying to get the engine running, when I connected that wire it kept the engine from firing. So I've left it disconnected? Should be a black wire with a purple stripe. Make sure that it's the same wire that connects to the back of the tach, and that it's on the right plug back there. If it is the same wire (the "continuity tester" function on your multimeter will help show that, or the ohmmeter function) and it's plugged into the right place, and it isn't shorted to ground somewhere, then your tach is hosed. And yes, it's supposed to connect to the same side of the coil as the points wire. --DD |
jdlmodelt |
I have a wire there that I have not connected yet. So you are saying it connects to the negative side of the coil? That's the side I have the points connected to. It makes a very small spark when I touch it to the negative side of the coil. Back when I was trying to get the engine running, when I connected that wire it kept the engine from firing. So I've left it disconnected? Should be a black wire with a purple stripe. Make sure that it's the same wire that connects to the back of the tach, and that it's on the right plug back there. If it is the same wire (the "continuity tester" function on your multimeter will help show that, or the ohmmeter function) and it's plugged into the right place, and it isn't shorted to ground somewhere, then your tach is hosed. And yes, it's supposed to connect to the same side of the coil as the points wire. --DD Thanks DD! That was the most clear and concise instructions I have received to-date! I can do that. So...what is the "right" connector on the back of the Tach? |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
I forget the numbers, but you can look at the nice color wiring diagram over at Pelican Parts. BTW, the wire in question is a relatively thin black wire with a purple trace. DO NOT attach the thicker black wire with the red trace! You'll waste the points and the condenser, as well as the point wire! All the smoke will get out and they won't work any more.
The Cap'n |
jdlmodelt |
I forget the numbers, but you can look at the nice color wiring diagram over at Pelican Parts. BTW, the wire in question is a relatively thin black wire with a purple trace. DO NOT attach the thicker black wire with the red trace! You'll waste the points and the condenser, as well as the point wire! All the smoke will get out and they won't work any more. The Cap'n Nope the big wire is on the positive side of the coil. I'll chase down the smaller one and make sure it goes to the back of the tach when I get home tonight. So the tach is just a pulse meter. |
jdlmodelt |
i swapped the brown grounds to the terminal labelled - and put the tach wire on the opposite terminal and got a somewhat fluctuating rpm reading on the tach but the engine clearly was missing and running rough until I disconnected the tach wire from the coil at which point the engine started and ran smoothly again. I need to find a visual of the connections on the back of the tach meter.
cwpeden |
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada ![]() |
Tach wire goes from the neg. side of the coil to the relay board(black with purple trace). This is terminal one on the coil. See link to diagram: http://www.pelicanparts.com/914/parts/Elec...lectric_73C.jpg
Your coil is item 6 bottom right regulator plate is bottom left From there it goes to the regulator plate though the 12 pin connector at the back. Pin number 5: http://bowlsby.net/914/WiringHarnesses/HarnDia_IGN_73-76.jpg Out the other end of the Regulator plate through the 14 pin connector through pin 7 then the harness to your tach again conncting to terminal 1: http://www.pelicanparts.com/914/parts/Elec...lectric_73A.jpg Tach is item 22. The 23 on the diagram at the end of the wire is to identify the carryover from the other diagram. I count 6 connections to cause a problem. Four at the regulator plate alone. Make sure they are all clean. I've had way too many problems caused by a dirty Reg. plate. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:30 AM |
