> Flywheel dowel pins
CG-914
post Jan 8 2013, 10:04 PM
Had my engine for machine work at Rimco,
and after they forget to send parts back I know finally after ... (IMG:style_emoticons/default/dry.gif) I have my dowel pins from the flywheel back I send in case they needed them for the balancing.
I am not sure if they send me the right pins back so here are the pics with measurements...
CG-914
post Jan 9 2013, 10:03 PM
Does somebody have a set laying arround he or she can compare the size?
20 mm x 6 mm
worn
post Jan 10 2013, 09:37 AM
can't remember
QUOTE(CG-914 @ Jan 9 2013, 08:03 PM) *
20 mm x 6 mm
Yeah, I have three out, waiting to go back in. I will try to remember tonight. Right off the bat though, the ones you have look spot on.
SLITS
post Jan 10 2013, 12:35 PM
"This Utah shit is HARSH!"
They are 6 mm O.D.
They stick out of the flywheel approximately 11 mm on the one I measured. Sorry, not pulling them out to get an overall length.
pilothyer
post Jan 10 2013, 06:43 PM
Just saw this.....Looks like they sent you the correct ones..........Jerry
- Lo-Fi Version Time is now: 21st September 2024 - 07:12 PM
