Permatune CDI box repair ? |
scotty b |
Jan 26 2013, 10:34 AM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Has anyone ever repaired a bad Permatune box for a 6 ? I have one in a 911 that was installed brand new and it owuld appear that almost immediatly it wen tbad. The car then sat indoors for almost 20 years. Bench tests fine until I go to the ground (D ) to B. I get and overload there, I assume there is a blown capacitorma-jiggy ??? (IMG:style_emoticons/default/confused24.gif)
Attached image(s) |
SLITS |
Jan 26 2013, 10:42 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Not an expurt but I've always been told they are "potted" and not repairable.
Never tried to take one apart. HARNESS PIN OUTS A = + or 15, coil hot primary terminal ( - or 1, coil ground primary terminal is connected to the engine ground). B = Power from ignition switch. C = Distributor breaker points. D = Ground BENCH CHECK OF THE IGNITION BOX (Perma-Tune only) PIN A TO D = 3,300 Ohms +/- 100 is normal . Zero Ohm or lower than normal resistance indicates defective ignition coil damage to the box. PIN B TO C = 100 Ohms, +/- 1 is normal. Open circuit or higher than normal resistance indicates ground loop or over voltage damage to the box. PIN D TO MOUNTING FLANGE = Zero Ohms is normal. More than 0.2 Ohms indicates ground loop or battery terminal reversal damage to the box. PIN D TO PIN B = 220uF to 250uF.This reading requires the use of a meter capable of measuring capacitance. Polarity sensitive. Pin B is positive. Any other reading indicates over voltage damage to the spike suppression circuit of the ignition box. |
scotty b |
Jan 26 2013, 10:52 AM
you're potted (IMG:style_emoticons/default/rolleyes.gif)
The thing that really sucks ( besides the price ) is the new units they sell look nothing like the original units. For the new price of 560.00 I'll see if one of the local geeks can repair this one. At least it wil look and mount correctly (IMG:style_emoticons/default/dry.gif) |
Phoenix-MN |
Jan 26 2013, 10:57 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Not true, Not all are "potted" I have two from about 20 years ago (still working) for my 911. Ones Blue and ones silver, neither one is "potted" With some basic testing tools they should be repairable
SLITS |
Jan 26 2013, 11:02 AM
Edited first post with info from Permatune even though I am (IMG:style_emoticons/default/smoke.gif) ed.
I have had several ... couple of blues and one silver (think I gave it away). Car runs better with the Permatune over the Bosch unit. |
904svo |
Jan 26 2013, 11:30 AM
904SVO Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Check the Pelican site there was a article showing the parts and how it works, which can be used to repair it.
scotty b |
Jan 26 2013, 12:02 PM
WOW (IMG:style_emoticons/default/blink.gif) I couldn't find the specific thread you mentioned SVO, But after reading some of the other threads on Permadooms/ Permacraps etc. I'm thinking it isn't worth the effort of repairing it. Looks like it's going to be a rebuilt BOSCH unit
sixnotfour |
Jan 26 2013, 12:05 PM
914 Wizard Group: Members Posts: 10,681 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
The Blue permatune boxes are good, If you find one don't be afraid to use it. actually installed by Porsche.
there are some red one too that are good. |
larryM |
Jan 26 2013, 01:28 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
sean_v8_914 |
Jan 26 2013, 02:44 PM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
clean, de-flux, re-flow the solder joints
must be done by someone with GOOD soldering skills, the CORRECT tip size and temp range. if you dont understand that statement then it aint for you. |
scotty b |
Jan 26 2013, 03:44 PM
clean, de-flux, re-flow the solder joints must be done by someone with GOOD soldering skills, the CORRECT tip size and temp range. if you dont understand that statement then it aint for you. Yeah I understand that, but it doesn't address my question at all (IMG:style_emoticons/default/dry.gif) |
sean_v8_914 |
Jan 26 2013, 04:10 PM
yes, I have done this and now it works
Lo-Fi Version | Time is now: 26th December 2024 - 08:33 PM |
