billh1963 |
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States ![]() |
I'm thinking of converting the Zambezi Green car over to 5 lug Fuchs (no flares) and am trying to understand if 5 lug suspension pieces are really necessary versus just drilling the current hubs?
This will not be a track or autocross car...simply a driver. I actually do have the parts to convert (struts and stuff from a 1970 911); however, I was just wondering if there is any reason to actually make the conversion for a street driver. Other than the benefit of getting the bigger 911 brakes on the front, is there a strength, reliability, adjustability, etc. issue? Thoughts? |
KENNY |
Member ![]() ![]() Group: Members Posts: 142 Joined: 5-February 03 From: Orlando fl. Member No.: 243 Region Association: None ![]() |
I am changing my to 5 lugs . I think i am going whit the drill hub.i whant to keep car close to original as possible .is just every other day driver .
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
If your not putting a lot of miles on the car then drilling isn't a bad option. A lot of miles means drilling a new rotor every time one wears out.
Jgilliam914 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,328 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest ![]() |
Ive had both options. The drilling of the hubs worked fine although I feel a lot more confident in having the factory 5 lug conversion.
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
I'm thinkin' put a 911 front suspension on like from an SC where you get M calipers and drill the rears. That would be very close to a -6 with the vented fronts and able to keep the parking brake in the rear. You probably know -6 rear calipers are unobtanium ... why mess with sourcing $$$ rear stub axles ...
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Drilling the rears I think is fine. Use all 914 bits except have the 914 rotor drilled for 5-lug.
You can drill the 914 front rotor ok but the next time you change rotors you have to re-drill. Benefit of 911 front end (a-arm + strut) is bigger brakes, vented rotor, integrated underbody sway bar (I hope this doesn't start a battle (IMG:style_emoticons/default/hide.gif)). They can be found inexpensively and they bolt right in. You can always use the 911 strut by itself with the proper ball joint. |
billh1963 |
As little use as most of our cars get, I would imagine that a rotor lasts a long time. Does someone sell predrilled rotors?
Like I said, I do have all the bits to convert; however, I'm just not seeing the benefit of making a full conversion. Would it be awesome? Absolutely! But for the casual driver what are the benefits of a full conversion? Is braking really that much better? |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Good questions, Bill. (IMG:style_emoticons/default/popcorn[1].gif)
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
I bought pre-drilled rotors about 9 years ago. 25,000 miles later, they don't show much wear at all. I bought them from a shop in Temecula Ca. I'm not sure if they are still in business. Ap. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Did you really have to ask "Who sells Predrilled Rotors ?"
PMB the fish guy |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Lots of things to weigh but, as stated early on, drilling the hubs and rotors can net you a very safe solution for much less.
If you go the factory route you'll be in for struts, inserts, rotors and new calipers. Check out my 5-lug conversion thread and it should weigh out all of the options. http://www.914world.com/bbs2/index.php?showtopic=105728 Signed... The Fish Guy (not sure what that means but if Jeff said it then...) (IMG:style_emoticons/default/confused24.gif) |
sixnotfour |
Salmon
r_towle |
Lots of things to weigh but, as stated early on, drilling the hubs and rotors can net you a very safe solution for much less. If you go the factory route you'll be in for struts, inserts, rotors and new calipers. Check out my 5-lug conversion thread and it should weigh out all of the options. http://www.914world.com/bbs2/index.php?showtopic=105728 Signed... The Fish Guy (not sure what that means but if Jeff said it then...) (IMG:style_emoticons/default/confused24.gif) What would the price be for your parts? the Cheap-elite option. Front rotors (drilled 5 lug) Rear rotors (drilled 5 lug) Rear hubs (drilled with extra boss applied) I would hold off on studs until I figure out what wheels and spacers I will use. Rich |
KENNY |
Lots of things to weigh but, as stated early on, drilling the hubs and rotors can net you a very safe solution for much less. If you go the factory route you'll be in for struts, inserts, rotors and new calipers. Check out my 5-lug conversion thread and it should weigh out all of the options. http://www.914world.com/bbs2/index.php?showtopic=105728 Signed... The Fish Guy (not sure what that means but if Jeff said it then...) (IMG:style_emoticons/default/confused24.gif) What would the price be for your parts? the Cheap-elite option. Front rotors (drilled 5 lug) Rear rotors (drilled 5 lug) Rear hubs (drilled with extra boss applied) I would hold off on studs until I figure out what wheels and spacers I will use. Rich If you don't mine I will be interest in price two .i need same thing but whit studs for 6x15 wheels |
billh1963 |
What's the deal with all the piggy backers? (IMG:style_emoticons/default/av-943.gif)
Spoke |
r_towle |
screw in works for me, and according to Eric's article it makes more sense.
We are not piggy backing, we are getting more facts for you to decide which way to go forward. Assuming price is one of the input variables to your decision making process. rich |
billh1963 |
screw in works for me, and according to Eric's article it makes more sense. We are not piggy backing, we are getting more facts for you to decide which way to go forward. Assuming price is one of the input variables to your decision making process. rich I was teasing...the more the merrier. Maybe we can talk Eric into a group buy? (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/poke.gif) |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Ok, it's time ................
Three reasons: 1.) More choices in REAL Porsche wheels. 2.) Bigger brakes (I drive fast). 3.) To be able to hold your pinky up, drink whine, eat cheese and wear gold chains. |
KENNY |
Sorry .i didn't know you we're so delicate . I was thinking the more people the better the deal . I am out |
Lo-Fi Version | Time is now: 26th June 2024 - 02:49 AM |
