rsrguy3 |
Member ![]() ![]() Group: Members Posts: 136 Joined: 4-April 09 From: Utah Member No.: 10,234 Region Association: None ![]() |
I want to eliminate all the slop I can from my side shifter. I like the idea of the Jwest & tangerine stuff but want to fab my own. Please share your suggestions/experiences, and please PICS! -Guy Oh! what ever happened to Velios? __________________ |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Here are a few pics from my JWest linkage install:
http://www.914world.com/bbs2/index.php?s=&...t&p=1031305 (IMG:style_emoticons/default/driving.gif) |
rsrguy3 |
That.....Sir Andy is beautifull!
rsrguy3 |
I am local Eric, I'll take you up on it when I get back for R&R.
rsrguy3 |
What kind of home brew stuff is out there? Pics guys we know your proud of your work.
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
The JWE Side-shift linkage kit isn't being produced any longer?
Why??? |
speed metal army |
Waiting for the rain to stop... ![]() ![]() ![]() Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada ![]() |
Slothness had a pretty rad one...
http://www.914world.com/bbs2/index.php?sho...=186850&hl= |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
here is what we did ourselves:
I've got a bunch more pictures in my vintage car build thread Attached thumbnail(s) ![]() ![]() |
rsrguy3 |
I like it Brant. Eric where did your pic's go?
BKLA |
Really old member ![]() ![]() ![]() Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest ![]() ![]() |
The JWE Side-shift linkage kit isn't being produced any longer? Why??? My guess ...Expensive to reproduce.... Limited market I have the jwest set up in my race car. And part of a jwest setup (rear assembly and firewall bearing) where I used my own limited fab skills to use steering shaft steering joints to complete in my street car. Very happy with both!!!!!!! |
brant |
I like it Brant. Eric where did your pic's go? we turned a delrin bushing for the firewall, made to fit and we put an apex bushing at the front of the linkage too plus an ajrs shifter dual brass bushings, and as you can see an extended cup for the cup bushing. the shift rod is dead straight because of the -6 conversion |
HarveyH |
Member ![]() ![]() Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 ![]() |
I believe Racer Chris (Tangerine Racing) \; see our Vendors...) lists a very similar side shift conversion kit on his website....
Harvey |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
I believe Racer Chris (Tangerine Racing) \; see our Vendors...) lists a very similar side shift conversion kit on his website.... Harvey The JWest kit had a DIY shift rod, but the short shaft carrier bolted in place without modifying the transmission shift console. My kit has a finished shift rod but installation of the short shaft carrier requires cutting the ear off the console. Some of my design criteria were based on experience with installing JWest kits for customers. |
dadaDaveed |
Member ![]() ![]() Group: Members Posts: 111 Joined: 19-February 09 From: San Antonio, TX Member No.: 10,071 Region Association: Southwest Region ![]() |
I have the Tangerine kit with the spherical bearing at the firewall and JWest Rennshift. Racer Chris made a custom shift rod to work around my LS1. The car's not on the road yet, but the shift action is SMOOOTH and crisp (IMG:style_emoticons/default/beer.gif)
rsrguy3 |
Good stuff! What kind of pics do you guys have of more diy stuff?
euro911 |
I have the Tangerine kit with the spherical bearing at the firewall and JWest Rennshift. Racer Chris made a custom shift rod to work around my LS1. The car's not on the road yet, but the shift action is SMOOOTH and crisp :beer1 I modified one of Chris' firewall bushings to fit my particular application.![]() The section of the firewall where the bushing goes had to be reinforced with a 1/8" aluminum plate (as the hole had been hogged-out by a PO) ![]() Taking 3/8" off the back side of the bush housing afforded the clearance I needed in the engine bay (front shift coupling hit the bush housing), but I still have a little binding due to a bad angle or an offset that I still need to straighten out. |
rsrguy3 |
This is exactly the stuff I was hoping for as many pictures and experiences in one place, it will make for a sweet referance thread.
Lo-Fi Version | Time is now: 26th June 2024 - 02:55 AM |
