Fuel tank strainer/sock replacement |
Hammy |
Feb 26 2013, 09:55 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
I have my tank pulled out to replace the strainer/sock. I can't seem to figure out how the sock removes from the outlet nipple. I know there's a crush washer that goes in there somewhere but I'm not sure I'm seeing it. Any help?
Have a pic for reference. This is with the strainer/sock cut off. Attached thumbnail(s) |
yeahmag |
Feb 26 2013, 10:02 PM
Advanced Member Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
The end of the sock is the light colored metal sitting on the "lip" of the nipple. Just slide a utility knife in there and it should pop off.
Hammy |
Feb 26 2013, 10:19 PM
Thanks. That's what I assumed but didn't want to force it.
Cevan |
Feb 27 2013, 06:51 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
When I replaced mine, the crush washer was built into the strainer.
JawjaPorsche |
Feb 27 2013, 07:09 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I am so glad this discussion has come up because I am going to replace mine when I replace my plastic fuel lines. If there is a way to screw it up I will! So I am asking questions! I took picture of what received. In the plastic bag was gasket ring. Can you tell me the assembly steps! Where does the gasket ring go? The crush washer, is built in? Thank you so much in advance!
Attached image(s) |
SLITS |
Feb 27 2013, 07:41 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Gasket under the nut ... strainer slips on and is held against hole in tank.
Mark Henry |
Feb 27 2013, 07:49 AM
Just an FYI, the strainer and washers are common aircooled VW parts
strainer 111-209-147-A washers 111-209-139 |
peteyd |
Feb 27 2013, 11:13 AM
Senior Member Group: Members Posts: 707 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
Is it really necessary to have the strainer? Shouldn't a fuel filter be sufficient enough?
I'm about to put my tank back into my car and don't see the purpose if there's a filter right after. Pete |
ThePaintedMan |
Feb 27 2013, 01:05 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Is it really necessary to have the strainer? Shouldn't a fuel filter be sufficient enough? I'm about to put my tank back into my car and don't see the purpose if there's a filter right after. Pete Because Porsche/Karmann designed it that way? Strainer keeps leaves and things that WILL eventually drop into the tank from clogging the lines BEFORE the filter. If you want to remove the tank again for fun, then just leave it out. (IMG:style_emoticons/default/biggrin.gif) |
Hammy |
Feb 27 2013, 02:30 PM
Is there anything I should be putting around the gasket or threads to guarantee seal?
SLITS |
Feb 27 2013, 02:47 PM
charliew |
Feb 27 2013, 02:49 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
All of the fi pumps I have seen suck through a sock and push through a filter.
Hammy |
Feb 28 2013, 03:41 AM
Ok so I hit the local VW shop today and bought a few items. I explained the fuel tank strainer I needed and the grommet/washer, he said he had what I needed in a kit. I didn't bother to take a look at it until I got home but what I got was an EMPI kit for what looks like a bug tank. The nut and felt washer that come with it look the same, but instead the strainer/sock is a plastic material. Is this going to work?
TheCabinetmaker |
Feb 28 2013, 06:05 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Go away Gerry. We hate spam here.
Hammy |
Feb 28 2013, 01:25 PM
Anyone know?
SLITS |
Feb 28 2013, 02:38 PM
Hammy |
Feb 28 2013, 03:11 PM
Hammy |
Feb 28 2013, 09:16 PM
(IMG:style_emoticons/default/dry.gif) So after opening the package to determine if it were the right size, I found that the plastic strainer is much too small to fit. I bet he won't return it either. (IMG:style_emoticons/default/mad.gif)
Which year bus will have the same size metal strainer? |
luskesq |
Feb 28 2013, 09:57 PM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
Google the part # given you and you will find that part went into a number of VW's, 1954-72 Transporter, 1956-1974 Bug, '73-'74 Thing, '66-'73 T-3's, and more. Any decent import shop or our usual vendors should have one and they are cheap.
Good luck, Keith |
Rotary'14 |
Mar 1 2013, 07:51 AM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
If you can't find it locally,,,, I have some of the metal style fuel tank socks,,, I can sell you one with 2 sealing rings for $12 via USPS in a padded envelope,, assuming you're in the continental USA.
-Robert |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:08 PM |
