skeates |
Member ![]() ![]() Group: Members Posts: 218 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California ![]() |
Hey guys, I've been putting together my set of Elephant Racing bushings for the front control arms, but seem to have run into a bit of a problem...
The bushing went into the front mounts without any problems (only needed the 100-150 lbs of force mentioned in the instructions). However, where they go into the rear mounts the fit is significantly tighter! For one I couldn't start it by hand like the fronts, and it definitely took more more effort on the vice to push in. The bushing seated...mostly, but now I'm noticing a bulge in the red poyl material and the busing won't seat any further into the mount (see pics below). I never measured the interference on the fronts, but I'm seeing somewhere close to 4 one-hundredths interference for the rear. Am I missing something here? I was thinking about using a torch to gently heat the mount it get it to expand a bit but I am worried that doing so could/will ruin the busing. Anyone else run into this problem before? ![]() ![]() ![]() |
Socalandy |
Its got to be Yellow!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California ![]() ![]() |
I had the same issue on one cup. I found it was slightly cockeyed and took several attempts to get in right. a little rotation on the way in seemed to help.
skeates |
Well, I suppose I'm relieved that I'm not the only one who's had this problem (IMG:style_emoticons/default/smile.gif)
When you say "several attempts" does that mean that you removed the bushing and then re-seated it, or do you mean that you rotated the whole assembly and then pressed again? I think that it may be a wee bit crooked, but not too much. In the vice I can get the bronze flange flush with the mount. but as soon as I relieve the pressure the bushing seems to pop back out to what you see in the above pics. Maybe I just need to keep at it? |
Socalandy |
looks like it's not seated right in your pictures, Same situation I had and we did remove and reinstalled it at lease 5 times until it went in without pinching the poly.
skeates |
Hmmm....sounds like fun. I suppose this might give me the excuse I need to convince the wife that a shop press really would make a useful addition to the garage. It could double as a wine press too! (IMG:style_emoticons/default/drunk.gif)
Thanks for the feedback Andy! I'll try pressing the bushing back out and then re-seating it. |
Lo-Fi Version | Time is now: 20th June 2024 - 09:06 AM |
