> Shifter slop, 914-6 edition, rear piece, not bushings
mskala
post Mar 7 2013, 09:07 PM
R
I'd like to know if anyone else with -6 linkage has seen this. The last
piece connected to the bar at the trans lever has 2 separate contacts/
movements, and even though I didn't see a wear pattern they were
both pretty sloppy. Below I'll show what I did for this.
The top channel contacts the ball of the trans lever. It has 18mils
of slop in it but the ball doesn't look worn. I decided the easiest thing
to do was glue in a 26-gauge brass shim with some 3M super90.
Perfect fit now. Even if this wears within a year or two, it's very easy
to re-do and I'm under the car a lot anyway.
But the fork side of the piece has HUGE slop. About 75 mils. It
actually looks like maybe somebody ground the opening wider
because the casting is smooth and rounded everywhere else. So,
this slop was taken basically to 0-5 mils by welding it and
re-grinding.
Sorry the pictures are only after being greased. It's still snowing
here so I won't even get to feel for improvement for a while.
Shim:
Side view after welding:
Rear view:
Dr Evil
post Mar 7 2013, 09:12 PM
Send me your transmission!
So, how does it shift???
Cap'n Krusty
post Mar 7 2013, 09:22 PM
Cap'n Krusty
Need another one of those? How about the nose cover/rod? I have 'em all, and they need to go away! Offers considered.
The Cap'n
Dr Evil
post Mar 7 2013, 09:30 PM
I have a need for a /6 tail cone. Is this what you are saying you have? Price?
mskala
post Mar 7 2013, 09:33 PM
R
QUOTE(Dr Evil @ Mar 7 2013, 10:12 PM) *
Engine not ready to run, 35 degrees in the garage, fluid is stiff. Won't
know for a while.
Mr.242
post Mar 7 2013, 11:04 PM
May your glass be smaller so it's always FULL!
Interesting way to shim the gap. Wondering if it works... (IMG:style_emoticons/default/confused24.gif)
jtf914
post Mar 8 2013, 05:42 AM
I have some wear on that piece but I haven't addressed it yet. Please give us an update once you get a chance to drive. I'm not too far fom MA if you want to get together sometime in the spring...
pcar916
post Mar 9 2013, 04:49 AM
Is that a Lola?
Will work just fine but a stainless shim would last longer if you don't simply replace the pieces. That's a lot of pressure on the two contact points on the ball. The brass won't like it forever.
mskala
post May 11 2013, 07:41 PM
R
Well I've been driving the car a bit, and my verdict is:
meh
Eliminating those gaps didn't seem to really change much. The car
didn't shift poorly before though.
toolguy
post May 11 2013, 08:56 PM
The ball on mine was worn. . but I was able grab it with vise grips and turn it 90 degree. . I welded the other worn spots and machined them back to orig specs. .
All in all, it's a tailshifter and still has some play in it .
Dr Evil
post May 11 2013, 09:24 PM
Yup, I convert a lot of /6 to side shifter for this very reason (IMG:style_emoticons/default/smile.gif) Not hard. Keep the old parts for originality if you want to later.
Cairo94507
post May 11 2013, 10:27 PM
Michael
Winner Winner Chicken Dinner! That's what the Doc did to my Six transaxle and I have all the original parts stored.
Dr Evil
post May 11 2013, 10:35 PM
Oh ya, the shipping was $32 (IMG:style_emoticons/default/wink.gif) I forgot to collect...
- Lo-Fi Version Time is now: 27th December 2024 - 09:13 AM
