You know those two holes.. |
stateofidleness |
Mar 16 2013, 05:13 PM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
..at the top of the transmission housing where it mates to the engine..
I think I dropped a tin screw in one of those holes (go figure.. (IMG:style_emoticons/default/headbang.gif) ) So now I'm assuming I need to check to make sure cuz I'm sure it'll be a bad day if it did go in there and I don't get it out... I've never separated a transmission from the engine in the 914. How big of a deal is it? Is anything gonna fly out if I just unbolt all the perimeter bolts around the edge? sigh... |
Eric_Shea |
Mar 16 2013, 05:16 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
It's one of those jobs you spend more time and effort worrying about than it actually takes to do it.
Jack'er up and support the engine. Put a jack under the tranny and remove the bolts. Slide it back enough so the fastener drops out. Installation is the reverse of this procedure. (IMG:style_emoticons/default/wink.gif) |
tomeric914 |
Mar 16 2013, 05:18 PM
One Lap of America in a 914! Group: Members Posts: 1,263 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
There's an equally big hole in the bottom of the transmission where it will eventually fall out. Even if it doesn't, I doubt it will do any harm.
Drop 100 screws in there and you may have a problem. (IMG:style_emoticons/default/w00t.gif) |
914itis |
Mar 16 2013, 05:45 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
There's an equally big hole in the bottom of the transmission where it will eventually fall out. Even if it doesn't, I doubt it will do any harm. Drop 100 screws in there and you may have a problem. (IMG:style_emoticons/default/w00t.gif) I agree! If it's stuck by the throw out bearing or any interior hardware you will notice it right away. The pedal may not depress or clutch will not disengage . If you start it and it drives fine, most likely you will be ok |
VegasRacer |
Mar 16 2013, 05:51 PM
ELVIRA Group: Benefactors Posts: 8,709 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Try Chopsticks. (IMG:style_emoticons/default/dry.gif)
stateofidleness |
Mar 16 2013, 07:00 PM
Success!!
stuck the air hose down the top side and watched the plume of debris fly out... then I heard the :clink: I looked near the bottom and there it was! Dab of axle grease on the tip of a screwdriver and it was out. Ahhh I can sleep easy tonight. Thanks fellas! (IMG:style_emoticons/default/beerchug.gif) |
billh1963 |
Mar 16 2013, 07:06 PM
Car Hoarder! Group: Members Posts: 3,405 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
That's dirty (IMG:style_emoticons/default/poke.gif)
914itis |
Mar 16 2013, 07:07 PM
Kool you did it! Now how the hell did you drop that In there with the transmission mounted?
stateofidleness |
Mar 16 2013, 07:17 PM
Engine and Trans are out of the car up on a stand.. was re-installing some tin pieces today and had the "baggie" of my screws sitting on top of the tranny. Took it out of the bag and wouldn't you know it? of all the places it falls into the hole in the top...
dirty is right!! I've been using everything to try to get this thing clean.. brake cleaner, degreaser, screwdriver, wire brush... stuff is hard as a rock and thick.... I don't even really know what it is. It's either CV axle grease, oil, or some type of "undercoating"... Engine leaked pretty badly from the pushrod tubes (already fixed) so I'm assuming it's many years of caked on oil spraying... damn PO's... |
steuspeed |
Mar 16 2013, 07:37 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
I have crap like that all over my transmission too. It looks like globs of black tar. (IMG:style_emoticons/default/confused24.gif)
bandjoey |
Mar 16 2013, 09:45 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Simple Green. Spray it on. Soak 10 minutes. Scrub brush. Garden hose it off. Repeat as needed. Simple will devolve paint after 5-6 hours so wash it down good.
Lo-Fi Version | Time is now: 27th December 2024 - 11:17 AM |
