Removing heater controls |
Alphaogre |
Mar 18 2013, 11:37 PM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
Do you have to remove all the cables and electrical to have the heater controls come out, or can you push all the leavers and the mount back inward. I have the face place off, but now its time to get the bulk of it out. Any tips or tricks? Its a 1970 914-4 BTW
914werke |
Mar 19 2013, 12:13 AM
"I got blisters on me fingers" Group: Members Posts: 11,030 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Its about a 7 on the difficulty scale, anyway you look at its a Bitch!
Remove the electrical. A 10mm nut mounts the back of the control frame to the bulkhead. Then you have to loosen two 8mm clamp bolts to free the three cables. last the cables have a dogleg in each end that secures it in each lever arm. All of this either on your back or in very tight quarters. |
type47 |
Mar 19 2013, 06:11 AM
Tedman5 |
Mar 19 2013, 08:57 AM
Member Group: Members Posts: 122 Joined: 25-January 08 From: Lebanon, PA Member No.: 8,627 Region Association: North East States |
Alphaogre.... are you deleting your heat? If so I can take those cables off your hands granted they come out without the dogleg breaking off like mine did.
Alphaogre |
Mar 19 2013, 10:03 PM
Its about a 7 on the difficulty scale, anyway you look at its a Bitch! Remove the electrical. A 10mm nut mounts the back of the control frame to the bulkhead. Then you have to loosen two 8mm clamp bolts to free the three cables. last the cables have a dogleg in each end that secures it in each lever arm. All of this either on your back or in very tight quarters. Thats what i was worried about...it seems like it would go inward but its hitting by just a few mm...damn it! Thanks for the info! Alphaogre.... are you deleting your heat? If so I can take those cables off your hands granted they come out without the dogleg breaking off like mine did. Wasnt planning on it, but its its possibly on the table now haha |
Dave_Darling |
Mar 19 2013, 10:20 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I think there's also a nut you have to remove from the trunk side of things... And there are a "few" things in the way there, like the fuel tank...
--DD |
Lo-Fi Version | Time is now: 27th December 2024 - 10:14 AM |
