any tips on cleaning transmision |
wes |
Mar 22 2013, 12:35 PM
wes Group: Members Posts: 1,591 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I have pulled the transmission on my parts car removed lose oil and grime with Gunk spray let it sit then took it to the car wash tried cleaning it up with the engine cleaner at the car wash, started to scrape the (IMG:style_emoticons/default/screwy.gif) build up mess with plastic scraper and much of it just wont come off well its certainly much better but I want it nice and clean looking like my new engine any tips on cleaning years of baked on gunk?
ThePaintedMan |
Mar 22 2013, 12:39 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Well, I was able to decipher what you were saying even though there wasn't a period anywhere in your post. (IMG:style_emoticons/default/blink.gif) Dr. Evil will kill me for saying this, but I used a couple cans of brake cleaner. A lot of guys don't believe in this because it strips away the original coating that was on the transmission to protect it. After I got mine clean I repainted it silver though, just in case. Good luck!
mrbubblehead |
Mar 22 2013, 01:02 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i use aircraft paint stripper.
steuspeed |
Mar 22 2013, 01:21 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
If you get it clean and want to paint it, I recommend Aluma Blast from Eastwood. I'm doing my Alfa trans with it and it looks great.
http://www.eastwood.com/ew-aluma-blast-set.html |
914Eric |
Mar 22 2013, 01:33 PM
Member Group: Members Posts: 316 Joined: 7-November 12 From: Northern Idaho Member No.: 15,125 Region Association: Pacific Northwest |
I put a little heat to mine with a torch and it melted off like butter.
chads74 |
Mar 22 2013, 02:33 PM
Member Group: Members Posts: 386 Joined: 13-March 12 From: Tampa, FL Member No.: 14,252 Region Association: South East States |
I put my kids to work srcapping at mine, after a couple days and a new coat of silver paint it looked pretty good.
Jeffs9146 |
Mar 22 2013, 02:40 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I use AWSOME from the $ store! It works great!
spray on and let it sit for 10-15 minutes, use a wire brush and a screw driver to loosen the tough stuff and spray more on. Let it sit for a few more minutes and hose it off! If you have a pressure washer even better! Repeat until clean! 2 - 3 times should be enough! Attached thumbnail(s) |
Dr Evil |
Mar 22 2013, 03:11 PM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Brake cleaner is fine. Water is not if it gets inside. I use the Awesome that Jeff speaks of since he posted about it a while ago. Ez-off was my old go to, but Awesome is too cheap and easy not to use.
Mblizzard |
Mar 22 2013, 03:18 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
There are a lot of harsh cleaners that will do the job. But as many others have said, a little heat goes a long way. While I am not willing to use a torch on mine, warming the trans with an electric heater or heat gun will help a lot. Also any water based cleaner will work better when warm.
Just be careful about trying different cleaners one after another and creating a situation where you are mixing chemicals. So bad and dangerous things happen when chemicals are mixed. Fully rinse one cleaner before trying a new one. |
gms |
Mar 22 2013, 03:27 PM
Advanced Member Group: Members Posts: 2,708 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Brake cleaner is fine. Water is not if it gets inside. I use the Awesome that Jeff speaks of since he posted about it a while ago. Ez-off was my old go to, but Awesome is too cheap and easy not to use. are you guys referring to this? http://www.awesome-cleaner.com/ |
Andyrew |
Mar 22 2013, 03:30 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Jeffs9146 |
Mar 22 2013, 03:32 PM
Yep thats the stuff! (IMG:style_emoticons/default/beerchug.gif) LA's Totally Awesome |
Madswede |
Mar 22 2013, 05:19 PM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
As for protection after cleaning, mine was coated with Cosmoline. www.cosmolinedirect.com ... Pretty sure it's close to what the 901 tranny came with from the factory. Richard Casto at Blue Sky Motorsports did mine. I'm sure he can talk to the specifics.
Dr Evil |
Mar 22 2013, 05:37 PM
The factory coating sucked! It does not last the life of the gear box, it is gone after a few years. I wont use it. There is better stuff out there that lasts much longer.
wes |
Mar 22 2013, 05:49 PM
You guys are great thanks! I had no idea that the case was coated with anything other than engine oil and road dust!
Madswede |
Mar 22 2013, 06:07 PM
Before I get corrected, Rich used something that was "Cosmoline like" I think. (IMG:style_emoticons/default/unsure.gif)
Anyway, what do you use then Evil? |
gopack |
Mar 22 2013, 07:07 PM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
Brake cleaner is fine. Water is not if it gets inside. I use the Awesome that Jeff speaks of since he posted about it a while ago. Ez-off was my old go to, but Awesome is too cheap and easy not to use. are you guys referring to this? http://www.awesome-cleaner.com/ I used that Awesome at the Disco Bay tranny clinic, Jeff gave me a spray bottle full!. sprayed it on, drove the shell to the car wash (guts removed) and pressure washed it, looked great! Jeff gave me a spray bottle full! |
injunmort |
Mar 22 2013, 07:23 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
I am by no means authority, but it is my understanding that the transmission case is magnesium. based on that assumption cleaning it with whatever not corrosive means is fine, but once that is done, it needs to be painted or otherwise coated. mag oxidises and becomes brittle in no time if not protected from the atmosphere. on my matchless g50 the cases and hubs were mag and had an aluminized gold paint that was on any of the magnesium parts. it used to turn green overnight without a barrier.
Jeffs9146 |
Mar 22 2013, 07:44 PM
I am by no means authority, but it is my understanding that the transmission case is magnesium. based on that assumption cleaning it with whatever not corrosive means is fine, but once that is done, it needs to be painted or otherwise coated. mag oxidises and becomes brittle in no time if not protected from the atmosphere. on my matchless g50 the cases and hubs were mag and had an aluminized gold paint that was on any of the magnesium parts. it used to turn green overnight without a barrier. I would guess it is more of a east coast thing because of the salt on the roads! I have not had any problems here in central california! |
Dr Evil |
Mar 22 2013, 07:50 PM
There is at least one thread that covers this ad nauseum. Check them out (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 26th December 2024 - 07:27 PM |
